I have the same one cts761?...it's great. Looking to order the green housing from SO so it will match my cts761g 3/8 impact
yep.
I can see why! This one is my new fav.
Now I just need the extra long fixed head, the stubby, the roto head, the 3/8 in the 1/4 body, all the hard handle ones, all the soft handle ones, and all the 1/4 and 1/2 matching ones...
Goals man...goals
how much does that wrightgrip set run?
edit: googled and answered for myself... around $230 on amazon
Next purchase will be set #915.
I think that was probably me. I ran a bolt thru mine and welded the nut on the other side. It took away that slop that it has. I also ground down the jaws a little to make them meet perfectly. By the way the factory rivet comes off like nothing. I basically sneezed on it and it came out
A month ? I guess their opening statement goes out the window then ?My 958 set was $230 which included tax and freight. Ordered and picked up locally and the Wright plant is in Barberton, Ohio. Still took close to a month to get.
The 915 is full polished and have the wright grip just like the 958. Not sure on the 715 set if it has the wright grip.
http://www.wrighttool.com/pub/default.asp?oid=266BE1D9-FF19-11D3-8B5D-00A0C942294E
Does Wright have two versions ? I see the Wright+grip and other sets without the "grip" in the descriptions.
I understand Snap-On has the standard FD(tootheless open end) and FD+.
Got this deal off the truck today. Buy the 3/8 set, and get the 1/4 & 1/2 set free.
....B1 G2?
how much was that set?
Yes. A call to the distributor confirmed that. However "grip"is not even available on the DOE sets. Stupid move on their part.I probably could have invested in those for the rare occasion "teeth" might come in handy.I Don't believe so, my understanding is that all new Wright production is WrightGrip.
Sent from my 0PJA2 using Tapatalk
EDIT: Oddly, to add to this goofiness, Protos angle open ends aren't available in ASD. You'd think when something demanded an "open end only" solution and doubling that problem to an "angled double open end only"...teeth would be mandatory.
If that didn't work the Victor wrench is the only thing left.
Went to Japan and the Phil. got some goodies
yep we get shafted over here and the dollar is so bad ATM its not even worth buying stuff from overseas
Any idea what the difference is between set 915 and 715? Can't really see why one set is double the price, and amazon's descriptions leave a lot to be desired...
What is the 10pt 20 for??
could be for Civic suspension![]()
