The other portapower thread motivated me to break mine out, so I drug it out from under the bench. I haven't touched it probably 2-3+ years, maybe longer. Its a Taiwan made Jong Maw 4-ton set, and came with the usual attachments.
Of course, when I opened up the box, it had leaked a significant amount of hydraulic fluid. I *believe* I located the fill screw, and removed it. I assume I fill it to level of the top of the cylinder, but not sure. Can I use regular hydraulic oil, or should I use jack oil?
As far as the leaking cylinder is concerned, is it possible or even worth it to try and repair?
