Snap-On plastic pry bar set(plastic clip tools)
90zcar
Does anyone have the plastic pry bar set from snap on?
Looks like this
Wanted to know the widths of the inside of the 2 sizes of bent forked pry bars
Pbn3 & pbn5 would be the two part numbers
Hammer1963
Kentucky
Yes, I have these and use them quite often. Good quality. There are 2 other sets that cover a huge array of uses. I cannot recall the manufacture.
90zcar
I ended up finding dimensions in the new catalog. Didn't expect that considering they aren't listing them on the website
90zcar
No it's cool. Thad's the problem when I post something under a pic.
Thanks tho. Just a heads up tho for anyone. The snap on plastic pry tools are NOT lifetime warranty
Brownsfan
Cleveland Ohio
My dealer replaced one for me. One thing I will say is these are by far the most durable plastic trim tools I have ever used. And I have tried most. These are worth the money.
454ragtop
Carver, MA
Might look at the SK ones, they look suspiciously similar. I have the SK's and a cheap import HF type set, the SK's are made of much tougher plastic.
HTH, JIm
amlv20
CEN-CAL
They are great! I bought the set two years ago,use them all the time for interior work and also to remove silicone gaskets on engine parts.
I don't care how much they cost or if no warranty,I'll buy them over and over. Way cheaper than having a screw driver slip and scratching a piano finish center consol trim that lists at $400!!never again!!!
harvey29
Kansas
Harbor freight has a set almost identical for $7. I use mine everyday as a auto tech.
90zcar
I have the blue harbor freight set that costs $5 bux and they are great. They do have a little more flex than I'd like at times. I really only need the wide fork one
