Another Drywall Question
Mendolat
Houston
The spacing in my garage for the ceiling joist are 36" on center. I want to be able to hang drywall and some of the suspended storage systems. What information do I need to get started with this renovation? Please see the pic below. Any help is appreciated.
Cyberbear
California
You first need to adequately reinforce your ceiling to support both the drywall weight and the proposed future load. Average drywall sheets like 16" centers but you are free to use whatever works best for your application.
icenfire01
South Dakota
I would run 2X4's parallel to you rafters 24" OC and attach 5/8 drywall or 16" OC and 1/2" drywall. Keep in mind that will add a lot of weight, Steel might end up being lighter and you might be able to attach that directly to your rafters but I don't know the maximum span for tin.
bczygan
DETROIT! Arsenal of Scrappers
You need to add at least one, and maybe two new ceiling joists between each of the existing ones, and check if the existing ones are adequate. You may need to use lightweight drywall or even a metal ceiling, depending on spans and loads.
You need to properly size and space the joists for the general area, and then look at the loads that the storage systems will add. Joists in these areas may need different sizes, spacing and material.
Also check if the header over your door will support these additional loads.
What is the header composed of?
Do you intend to store anything above the ceiling or insulate?
What is your span and what size are the existing joists? And check that spacing, 36" is odd.
Firebird 1
Maryland
Looks like 2 x 6 bottom chords, should be able to attach perpendicular strapping and use 5/8 drywall. I would use 2 x 4 if you have clearance. I would not use the above area for storage though. I would space the nailers at 16 oc
Whitworth
For your storage systems, add a beam (doubled up joist) at each location you plan on. Can't tell span, depending on that and load, size your beam accordingly.
Sheetrock: no one living above garage, 1/2 ultralight Sheetrock with strapping 16" on center. 1 by 4 strapping attached with screws is fine. 16 oc will give you a rigid ceiling.
Gary
Mendolat
Houston
The span is 20ft. Currently using 2x8. I figured I would add a couple more joists since I have one already not looking great. Should I go to a 2x12 or would that be too much weight?
dogdog
they have some metal furring strips or use 1x3x10 furring strips to make it 16" ?
bczygan
20' span
No storage
#2 Doug Fir 2x6's at 12"o.c.
1/2" DW
This means adding 2 new joists between each of your existing ones.
(This assumes that the existing joists are also at least #2 doug fir 2x6's)
Check other species for spacing, and size for the span and load conditions.
Or...
Use one new 2x8 joist between each of the existing ones. This will provide adequate support, but the spacing is off, so 1x or metal strapping at 16"o.c. across the joists, would be needed.
Also don't forget to check garage door header size.
Blocking at 1/3 points.
Whitworth
Put studs underneath your beam locations. And I think 2 by 12 is fine, maybe 2 by 10 depending on what you plan on hanging, but not smaller than that.
matt_i
SE Michigan
Amongst other issues it looks like you will also have to frame a "box" or "tray" for the garage door opener, simply because it is not below the plane of the horizontal truss members. When the drywall gets installed, taped, mudded, etc, the door opener will have to come down.
bczygan
20' span
No storage
1/2" DW
Or...
The above is from span tables you can find on the net. Check them yourself.
You need 5 items to calculate a joist.
Span
Max. deflection
Species/strength
Dead and live loads
Size/Spacing
Remember to calculate the storage areas for actual loads and check the door header.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Strapping and lightweight drywall.
No need to use the standard 5/8 drywall when you can get lightweight drywall instead. Lightweight is just as sturdy but a little over half the weight of standard drywall. Run you strapping 90 degrees to your rafters at 2' on centers. Screw the drywall on and call it good.
rickm_b
Google "hat channel", it's metal furring. Run perpendicular to joists 16 or 24 on center
