Which one you use more 12 or 6 point sockets
Autoguy
Riyadh/Saudi Arabia
SO and other manfacturers list more the 12 point sockets in their sets and catalogues. 12-point sockets works in tight places and will give you more swing than 6-point sockets. The 6-point sockets grip the nuts and bolts better and seems stronger than the the 12 ones.
I wonder :confused:how often the 12 points are used wether deep shallow or standard compared to the 6-points. I can say that 90 % of the time I rely on the 6-point sockets.
Southern Europe
I have set that are 6 point, sets that are 12 point and sets that are both. If I run into a bolt that I don't have a socket for the project stops til the right socket is bought.
volvo420coupe
central Michigan
since every ratchet made even cheap ones have more than 12 teeth, a 12 point fastener has no advantages of "swing" unless your working with a breaker bar or such, which is so rare that my 12 pt sockets are only for 12 pt fasteners or odd instances.
wantedabiggergarage
Member Emeritus
Independence, MO, USA.
12pt were common in the old days, due to both 6 and 4 sided fasteners. As 4 sided fasteners dropped away, people both used what they had (depression and wars hit), and found it beneficial (more starting points). Now that said, when I started, I was told to get six point by the old timers. They said I could find 12 point used, as well as use the shops, etc. and six point were stronger.
I should mention that I also have and have used 8 point, when I have worked on old stuff, and leave them and the 12 point in the drawer most of the time now.
A
Autoguy
Riyadh/Saudi Arabia
3/4 inch and larger sockets are mainly 12-points may be a carry over from the old days.
petty4243
LuVerne Iowa
i have both, but grad the 6 point first whenever possible... have found a few instances where a 12 point would go on to the fastener easier using 12 point... usually places where you can only get one hand in and hard to rotate socket to correct position with only the one hand.....
RRmech
Santa Fe, NM
Most of my older sockets are 12 point.....newer sockets, 6 point.
I'll grab a 6 point first.....IF.....I have one in the correct size.
Steve
Big Bad Jon
I have both but agree with my fellow Swedish motoring enthusiast. With the new high tooth count ratchets 6 point is probably what I would buy if I was replacing my sockets.
malibu101
Walnutport PA
I have full sets of both 6 and 12 point sockets. You know the disease. :)
I always grab the 6's.
The 12's are for when I need another socket of the same size, or in the middle of a job and I can't find the 6 in the mess of tools I know there's an easy to find backup. Or in a few odd cases I've run across 12 points, mostly Ford products.
Plus not using the 12's often keeps at least some of the tools looking pretty :)
plinker
Northern Wi
The only 12 PT you need for Ford stuff is for the driveshaft bolts, just get the S.O. 12 pt 12 MM at 1/2" drive and you'll be happy.
Some Ranger 4wd front driveshaft bolts are 12pt, most late '80s and up use T-30.
Mack trucks use 12pt bolt on the drive shafts and some in the engine.
Junkman
Northeastern CT
I prefer the 6 point, but I have both. It depends on what I am doing, as to which one I use. They both have there place, but knowing which to use when and where is the real question. The answer comes with age and experience. Use a 12 point on a rusted nut, and you are bound to round off the corners. Use a 6 point, and you might break off the bolt, but the head will still have all its corners. Knowing when that next turn of the socket is going to render you a broken bolt, is the really what counts. Some have the feel for it, and others only learn from bad experiences. The poorest quality of tools in the hands of an experienced mechanic will get the job done, and the very finest tools in the hands of the inexperienced will not make the difference. :thumbup:
Adam McLaughlin
Santa Rosa, CA
Oh yeah... That's right. I do recall the Rangers using 12pt 12 mm for the front driveshaft as well. Not just the rear end.
I do recall that my Bronco 2 had the torx stuff in the front, but I got rid of that when I swapped in the D44 in 2001. That's called being young, foolish with my money and getting my first credit card while being interested in 4x4 stuff.
Things I wish that I did differently..
Adam
LGMechanical
Etobicoke, Ontario
I work with transport trucks. 90% of the time I use 6 point sockets. Trucks have more clearance than cars so I don't use 12 point sockets unless I have to. (Bolt head is 12 point).
