LightningEngineer
- Joined
- Dec 28, 2012
- Messages
- 20
How can I make this design work? I have absolutely no idea how to use a tapered bearing. I'm pretty sure it is the type I want, however, how can I make the upper tool holder rotate without binding while using a bolt of some sort? I'm thinking if I use a nut of some sort up top it will prevent the entire thing from moving smoothly. Essentially what I think I need to do is isolate the shaft from the upper assembly to it "floats" on the bearing, right? I can CAD it, but I have no idea how to design it!!
Anyone have an idea as to how to make this thing work? I need to cut some concave shapes into the face of some 6" aluminum cylinders. Any help would be greatly appreciated!!!
