mark2457
Hi All
Just got detached garage requirements from village.
Drainage
It's at back of lot, so can't run gutters to front of lot. Does anyone know what specs are for a dry well? (depth, width, material, covering, etc.)
What the heck is "an open and improved public alley with positive drainage"
What does "Slab replacement permitted only if independent of frost depth foundation." mean?
Totally perplexed by this: "Minimum 12" trench with 20" bell on all four sides. Foundation to extend 4" above grade and a minimum of 42" below grade or formed footing and foundation."
I'm using siding, so does this mean the foundation/floor has to extend 6" above grade?
no clue what this means
Can anyone interpret for me?
Thanks
Mark
Drainage
Any new or rebuilt accessory buildings with a floor area over 400 square feet shall have gutters directed to the front of the lot to drain to the street, a dry well system, or an open and improved public alley with positive drainage. Subject to Engineering Division approval.
General Construction
Foundation & Floor
Masonry Construction
- 5" concrete slab on 4" gravel/stone base
- Minimum 12" trench with 20" bell on all four sides. Foundation to extend 4" above grade and a minimum of 42" below grade or formed footing and foundation.
- Minimum 6 bag mix with 5-6% air.
Frame Construction
Siding 6" above grade, brick to be 4" above grade.
Walls
Short walls to be braced per current adopted IRC.
Thanks
Mark
