porschedude996TT
I am starting a small business to service the wine making industry. My hopes are to keep me just a little busy in my retirement years. I love wine and wanted to be around the industry in a small way. I don't want to compete for the larger builds, just the small stuff. I have worked with stainless steel for many years and enjoy designing and improving where there are problems. I got my first small job that is more of a refurbishment than a redesign, although I did improve the handle pivot. Maybe that will be another topic.
So after needing a Blast Cabinet, (see other thread
http://www.garagejournal.com/forum/showthread.php?p=2506793#post2506793 )
I needed to replate the original hardware. I started with a small Nickel Brush type plating kit and was reall disappointed. So I bought the tank type plating kit in Zinc. Most bolts that you see these days that we call Cad-Plated and really Zinc. With this kit you can plate items to look like the old dull cad if you don't use the Zinc Brightner chemical in the plating solution.
It works pretty slick.
Picture 1 is the whole setup.
Picture 2 is the plating portion DC Constant Current, vary the Current based on the total surface area of the parts.
Picture 3 is the degreasing tank, no electric current in this tank.
Picture 4 is the Plating Tank with the pump to circulate the solution and a heater to keep the solution at 110F. Note the two Zinc Plates connected to the + power source.
Picture 5 are my first two pieces. Larger was the second piece. It has a better surface finish because od a lower current applied to the part.
Picture 6 is a the successful items.
content need to be copper plated to prevent this dull finish.
Picture 7 is of the best and worst of my efforts thus far. The Brass Coupling Nut came out almost like chrome. Gray plate had too much nickel to directly plate with Zinc, I would need to first plate with copper to get the best results.
It is a lot of fun and it may turn into a business all on its own. I plan to also Anodize as well in the near furture.
