Crown Imperial
May be Nepros and Subarus don't mix?
I Hate to play the Devils advocate but pieces of rubber on tools that get used hard are gonna wear fast, regardless of brand. Good to hear the you're enjoying the sockets though! [emoji106]I've owned these tools for about 3 years now and would like to give an update.
I only own the 3/8 flex head ratchet, a socket set, an extension set, and the u joint.
Ratchet lock and release no longer works. Sockets fall off easily and they can be pushed on without pressing the release button. The rubber "grip" at the bottom is long gone. These get oily and swell and then fall apart. On the sockets, they provide no grip at all. Hold the socket and twist, and the ring just spins around the socket. I'd much rather have some knurling on there to get a better grip.
The sockets, extension, and u joint have all held up just fine except the rubber ring. I will admit they have a better fit and finish than some ACE hardware brand tools, but I wouldn't buy their ratchet again.
Quite simply, the solution to all this is knurling like Hazet has always been doing.
My recent order came in.
I used an actual camera this time instead of the cell phone pictures above.
MIRROR FINISH, no doubt.
I want the tools, but nepros sure isn't cheap.
too nice to use![]()
and $116.- for a collectible... hmm
on the other hand there is always something more expensive:
http://ktcos.jp/urushi/index.html
So of this stuff will be polished more than used.![]()
Is KTC the manufacturer of the new Master Set tool chest EKR-1004? I was wondering if I could find it cheaper similar to how the old one was made by Waterloo?
