tweedlestan
Just wondering what GJers use for stuck bolts. Looking to get an oxy-acetylene setup soon, wondering what tips/attachments I might need.
Yep. With a selection of few tips you can pinpoint or spread the flame as needed to really heat up or burn out problems much more precisely than with most other gases.The oxy- acetylene torch is one of the most useful tools a guy can have in the shop.
Mapp gas is no longer available.
What kinds of things are you planning to do with your oxyacet setup? Thin panels, brazing, torch cutting, or just flaming stuck bolts?
I have a Victor setup that I bought in the '60's, and while I don't need it often, when I do it's great to have it. Just last weekend a neighbor was trying to change out a rear wheel bearing on an older Kia, the thing was really rusted into the backing plate. I tried the press first, but 20 tons of Harbor Freight might wouldn't budge it! So, I used the torch around the edges and one good pop from a three pound hammer and it was free.
It's just really handy to have, but unless you're going to use it to cut thick stuff, I wouldn't get a cutting torch attachment or tall bottles. (mine are about 2 ft tall)
A couple of tips in different sizes should suffice.
BTW, I can buy MAPP gas at my local Home Depot.
You can get the replacement for MAPP at Home Depot. MAPP is no longer made. What you are getting is Map/pro. I believe it is a propylene propane blend, whereas true MAPP had Methylacetylene-propadiene blended with propane in it.
Is there a difference in the flame temperatures?
If you are just heating and cutting, I'd consider a oxy propane setup instead.
