Ductile Iron vs Forged - Yost FSV-5
MrBreeze
Scottsdale, AZ
Over the past few months I've been reading nearly every post about vises I can find and checking CL nearly daily for a old american made vise with not much luck, so I'm turning to buying new. Yes, I know I'll be scolded for even considering buying new, and not wanting to spend several hundred dollars (or a couple grand) on a vise for what will be occasional use in the garage (I'm not making a living as a machinist as my father did for 50 years)
So with that said, here's my question -
Obviously tensile strength is important. Many new china/taiwan vises in the couple-hundred dollar range are Ductile Iron and around 30,000. I came across the Yost FSV-5 and it's Forged Steel and claims a 90,000 psi tensile strength and it's around $200.
http://www.amazon.com/dp/B00E8ITETS/?tag=atomicindus08-20
Not being a metallurgist - can someone explain such a difference?
Gray cast iron vs Forged steel - Forged is better, but why is this vise so relatively inexpensive?
Does anyone have any experience with this particular Yost vise?
Thanks,
banditbigdog
Southeast
I'm not sure this helps as I'm not an expert by any means on metallurgy, but here goes.
If you have a choice between similar vises one being forged the other being ductile iron or case iron then the choice is easy, go with the forged vise.
I do not own or do not have any experience with the Yost vise your looking at.
Upon looking at the photo in the link I will say this,
it looks a little "thin" where the movable jaw vertical portion meets the horizontal portion or "bar".
That would concern me if you have a need to really and I mean really clamp something tight on the outer part of the jaw and then exert a large force on that part which is clamped.
To me the jaw width vs. material that backs up the whole movable jaw is not proportional.
The vise in the link states a weight of 27 pounds.
That's pretty light for a 5" vise.
Here is a photo of another Garage Journal members vise which I would consider the jaw width proportional to the entire movable jaw.
View media item 20152
roguegts
First thing, if it's coming out of china/Taiwan it's US grade gray iron. They call everything ductile but it won't meet us spec. 30,000 psi (class b?) Is mediocre gray iron at that.
RivennHewn
PNW
I have the 4" version of that vise, and couldn't be happier with it.
That said, I don't ask much from it. I have a larger vise securely mounted to a bench, and the FSV4 is mounted to a table on castors.
Fit and finish is very nice, and the knurled jaws are parallel.
I did have to grind a slight bit on the underside of the base, to get it to sit flat.
It's a good vise for the $$$.
http://toolguyd.com/yost-fsv-4-heavy-duty-bench-vise/
Cyberbear
California
I am not sure after reading your post just what, or when, you are searching for in the way of an old American vise.
It's almost impossible to be certain what any used vise is made of; ductile , cast, forged, who really knows? If you need a vise now, then buy something that will work until something better is available.
If you can afford to wait, perhaps you can try and find a Craftsman bench vise made in the early 1960's that was advertised then with an unconditional life time warranty. I have two of these and they pop up on Ebay fairly often, but you need to seek them out. These have been great vises and have worked well for me over the years. If you need more info, ping me and I'll look it up for you in my archives.
PFSard
Mesa, AZ
You live in a tough neighborhood (AZ) for finding an old American made vise. It took me over a year to find a decent one - a Wilton 400S. The best opportunities I've seen are at estate sales. Good luck with your quest.
sberry
Brethren, Michigan
You want to work with it or collect? For real work its hard to beat a 5 or better yet 6 rotator with pipe jaws. Only way to afford it is imports but they are the ideal for small shop and super for hand fab like most of us do.
Cyberbear
California
If you want more Craftsman vise info, go to: http://www.blackburntools.com/articles/rose-tools-catalog-archives/sears/index.html
This site has the Craftsman Tool catalog for 1964 that shows the vises I mentioned. These were machinists vises with malleable iron castings, all working surfaces were machined, had hardened "T" jaw faces pinned in place, and were "Unconditionally guaranteed" or free replacement if they broke. The 3 1/2" vise weighed 32 pounds and cost $32.99 back then with an optional swivel base that weighed another 6# @ $6.99.
Sears also offered this series in 4" and 4 1/2" jaw sizes, at 42# & 45# respectively.
These are still some of the best older vises out there today and can be found used at decent prices. You can recognize these vises by the metal CRAFTSMAN nameplate pinned to the side of the vise body. Hope this helps some of the vise collectors out there, my count is up to about 30 different types, so far.
matt_i
SE Michigan
More or less, there are a couple types of material...grey cast iron, nodular (ductile) cast iron, and steels.
You get to cast iron by putting several percent ~4% carbon into the raw iron. It melts at a low temp and casts relatively easily. Nodular has a *lot* more toughness, its used for parts like steering knuckles that get beaten up and you don't want them fracturing. Nodular has to do with the spherical microstructure you see with a microscope whereas grey iron is more of a flaky texture. Back 100 years ago grey iron was the workhorse material. It still has some advantages like being the best wear material (think engine block cylinders and piston rings)
Steel is always less than 1% carbon, it melts at considerably higher temperatures. One can "freeze" the microstructure in a way that it would not normally be able to be if cooled naturally from molten. That is by quenching which artificially quickly cools the molten metal. Steel is of course the engineering workhorse material of today. Steel can be alloyed for toughness, for strength, its easily weldable...the list goes on.
So the Yost vise in question is a forging, its 75ksi steel which is sort of a medium strength. Low carbon steel is classically known to be around 36ksi.
You can see in the moving jaw that it looks like it would break immediately if struck as compared to the beefy old-school vise. Its sort of a more modern engineering material choice applied to a vise, and the design lightened to take advantage of the higher strength, and greater ductility material.
MrBreeze
Scottsdale, AZ
Thanks for the info and input.
I've gone without a vise for so long, so really most anything at this point would be an improvement for light-duty home owner and wrenching. I might go with something to bridge the gap as I continue to search locally.
As a follow up question, if you had a set budget of say around $200 would I be better off with a rotater (such as the Yost 750 DI)
http://www.newegg.com/Product/Produ...16&cm_re=yost_vise-_-9SIA08C2CE9016-_-Product
or a standard vise pivoting (non-rotating) vice?
http://www.amazon.com/dp/B004AH1IIM/?tag=atomicindus08-20
Those who have had the rotater-style, do you find yourself using that feature, or is the money better spent on a standard style vise?
Again, the use is LIGHT duty home owner and mechanic.
lynnbilodeau
Oklahoma
Off topic, but I have one that looks similar. It is a reed 204R. 4 inch jaws.
What does the 2 stand for in 204R?
banditbigdog
Southeast
Not 100% sure but I believe the 2 would indicate a 200 series standard machinist vise with a swivel base.
A number beginning with a 1 would indicate a solid base.
A number beginning with 4 would indicate a swivel base and swivel back jaw.
38Chevy454
Cincinnati, OH
As a metallurgical engr, this is good basic summary. Saves me typing.
A good ductile or nodular cast iron will have better ductility and toughness than grey cast iron, but not as good as steel. Most cast crankshafts today are made from nodular cast iron, as well as many other parts. Small difference in the microstructure between ductile and nodular cast iron, but the end result is better ductility of the final product.
Given the choice, forged steel is better for toughness and ductility. But casting is a lot easier (interpret as also cheaper) than forging, so lower end import production is cast. Assuming mostly home use where you will not be pounding on the vise with high shock loading, ductile cast iron is sufficient. Forged steel is better.
Grey cast iron has very low ductility, it is a poor choice for a vise. Good for engine blocks for example where the properties are matched to the application.
exmaxima1
Midwest
If I was prepared to spend $200 on a new forged vise, I'd buy a Ridgid. Made in Germany (AFAIK), and very good quality.
Wait for a discount code to pop up on Zoro, and snag this:
http://www.zoro.com/ridgid-combination-vise-swivel-4-12-in-jaw-fs-66987/i/G1794204/
sonoronos
Thanks,
First, please disabuse yourself of any notion that country or origin or cost has anything to do with the quality of a vise. There's only a weak correlation - no guarantee.
Second, understand that metallurgy and metallurgical science improves over time. It does not go backwards. For some reason, there seems to be a lingering sentiment that old=better and that is totally untrue. Old is only better if it's actually better by virtue of its design.
For example, note that even the king of GJ vises, the Wilton bullet vises, only started to be made of cast Ductile Iron in its modern incarnations. Early bullet vises were made in a time before metallurgy and iron production was able to provide the mechanical properties desired.
The reason cast ductile iron is used is because it's the only cast iron that has mechanical properties that are competitive with steels.
The 60,000psi rating of Wilton's Ductile Iron bullet vises is a tensile strength rating. I have never seen any testing data from Wilton showing that their vises actually are tested to 60,000psi tensile strength (no casting coupons, no destructive testing). Therefore, it only logically makes sense that Wilton's tensile strength rating is a reflection of some ASTM standard, which guarantees some minimum tensile strength. If that's the case, the yield strength of the 60ksi tensile vises would normally be consistent with a 40ksi minimum yield strength. This also corresponds to an elongation at fail of 18%, meaning that you'd see some pretty significant and noticeable distortion in the vise before it breaks, as opposed to gray iron vises, which have virtually 0% elongation and so shatter without a warning.
Where manufacturer matters in cast iron items is the quality and consistency of the castings. Let's say that a random manufacturer makes a cast ductile iron item rated to 60ksi tensile strength. We assume, ignorantly, that the properties of the cast ductile iron item is homogeneous, meaning constant through the entire casting. In reality, for many reasons, casting defects can appear inside the various areas of the castings. Differential cooling can cause stress rises in different parts of the castings.
Part of the "quality" aspect in a vise has to do with whether or not a manufacturer can tightly control the casting quality, and therefore improve the homogeneity of the casting. As a consumer, we can only verify this using first-hand reports and reviews.
The reason why manufacturers don't often use cast steel is because steel is difficult to cast. Its thermal expansion properties are higher than cast iron, which means that you have to cast larger and then machine the pieces to specification. This is why you see forged and machined steel vises. It's not because it makes a necessarily superior product - it's because they have to be post-processed to make the product precise enough for use.
However, the advantage of using steel is that, depending on its alloying composition, the material properties can be very high. Much higher than ductile cast iron. For low-carbon mild steels (like JIS S45C), compared to 60ksi ductile iron, you can have 25% improvement in yield strength (40ksi vs 50ksi) at a similar elongation. In general, most steels in that cast/forged range will have around 50ksi yield strength.
I disagree with an earlier post that says that if you took a hammer to the Yost vise dynamic jaw, it would break. It wouldn't break at all. It would take the shock, bend, then snap back. The dynamic jaw wouldn't break until it distorted to the elongation specified by the material at break.
Engineers know this and this is why the Yost FSV vises are thinner and lighter than equivalent cast iron vises. They have less cross sectional area because they need less material to have equivalent properties to cast iron vises. Less material means less cost (raw materials to build and less money to ship.)
And this is critical: Vises are not designed to be indestructible. They are designed to provide certain parameters of operations within a certain envelope. For example, let's say you need a vise that requires a 6" jaw opening. The Yost FSV-5 weighs 27 lbs and can open to 6 inches. The Wilton 1765 (which opens to 6.5 inches) weighs 70 lbs.
Taking the Yost FSV-5 and Wilton 1765 comparison further, note that the FSV-5 has a smaller throat depth of 3.25", while the 1765 has a throat depth of 4". Making the throat depth larger requires reinforcing the jaws because of the torque applied to the vise when clamping.
Assuming that the yield and tensile strengths of the Yost vise are higher than the Wilton by 25%, what the differing weights can tell you is this: The Yost vises have smaller mechanical cross-sections, which means that they will bend for a given force a greater amount than the Wilton vises. The Yost will experience greater deformation when abused than the heavier Ductile Cast Iron vises before breaking catastrophically.
If Yost made a vise that was identical in design to the Wilton bullet vises but made them out of their forged/machined steel, they would be incredible vises, superior in almost every way. But the cost of making those vises would be very, very high.
So what you're getting in the Yost is: Less weight, more working envelope for the weight, and can take somewhat more abuse than a Wilton before shattering. You also get much less stiffness, less clamping force before bending, and more flexibility. If you're clamping with a vise then flexibility isn't what you want.
IMHO, if you're looking for a vise that you're going to hammer on like a madman and abuse without abandon, get the forged steel vises. First, it's not "cheap" at all. $200 is a lot of money. If your idea of working with a vise involves sledgehammers and cheater pipes, then I would go with a steel vise.
VoodooCLD
Excellent write up sonoronos. I'd like to second that the old ductile iron vises are a proponent of yester-year and I'm eagerly awaiting the the arrival of beefy alloyed steel vises that can take repeated hammer blows. For a good price of course, the technology is nothing new.
rlitman
Long Island
... understand that metallurgy and metallurgical science improves over time. It does not go backwards. For some reason, there seems to be a lingering sentiment that old=better and that is totally untrue. Old is only better if it's actually better by virtue of its design...
Sonoronos, I too agree that is an excellent write up. But it misses two points.
First, while metallurgical science improves over time, that improvement empowers manufacturers to find shortcuts over time too. The foundation of engineering is to build the most, WITH THE LEAST. The more you engineer a product, the less product you will have in the end. And while elegantly designing a product to strictly meet design criteria is a good way to minimize costs and maximize profits, a less engineered design will often exceed those criteria by a wider margin (this = better), except when you're looking at imported **** that has no design criteria other than profit/store-shelf-space. Though I agree that imported does not necessarily equal ****.
Second, if you're looking to beat on a vise without abandon, consider that while a steel vise of equal weight to an iron vise will certainly perform better, vises are generally not valued by their strength:weight ratio. As pointed out above, the steel vise is pretty light for a 5" vise, and that lack of inertia may detract from the value of your anger management sessions. And yes, $200 may be cheap, if you compare it against an American ductile iron vise of the same size (but of significantly more mass).
kwoswalt99
Detroit
Most vises of yesteryear were made of gray cast iron. DI vises should stand up to a hammer.
kwoswalt99
Detroit
IMO a vise should be made to withstand a cheater pipe. You should be able to wrap the handle around the knob without damaging the vise.
sonoronos
You're correct for sure. Ductile Iron is a "modern" material.
Any vise made before 1943 is most definitely not ductile iron, correct? And even after that, it probably took the better part of a decade to achieve commercialization and later than that to achieve widespread adoption.
Before ductile iron's invention, my understanding is that the best that cast iron could do was "malleable" iron, which were basically alloyed cast irons that were chilled after casting, then annealed very slowly to prevent graphitization.
IMHO, cast ductile iron is basically the cast iron industry's attempt to be competitive with steel. So basically, the ability of DI to be hammered is about the same as steel of similar properties to withstand hammering. The benefit of steel is that its mechanical properties can be significantly stronger than Ductile Iron, near doubling or tripling its strength.
That said, there are some pretty terrible steels - A36 comes to mind, so whenever dealing with steel vises, you have be extremely sure of what alloy is being used. There are steel alloys that are inferior to cast Ductile Iron.
kwoswalt99
Detroit
DI wasn't somewhat common in industry until the 60's, and not in the vise industry until the 90's, possibly later.
matt_i
SE Michigan
I got a small chuckle because the world (skyscrapers, stadiums, the I beams holding up my shop and house, bridge cranes) is built of A36...granted A50 is sort of the new-norm but that's because mining it out of the ground and blast furnacing it into steel got too expensive and its better to recycle, and the carbon content crept up via mixing.
I'm going to WAG that a forged vise is 5x as much money to produce as cast. The workpiece is maintained red-white hot and has to be handled in and out of the press(es), nobody can touch it with hands, special D2 or S7 (I forget which one) dies are needed so the dies don't decarburize via diffusion due to the heat and pressure.
If its cast steel then sort of the middle cost-wise but definitely requires higher temps than pouring iron castings.
sonoronos
So what were Wilton Combination vises from the 80's made of? Or are you just saying that it was used in the vise industry, just not commonly?
sonoronos
Sorry - you're absolutely right that A36 is the norm for structural steel. Great when making things that need strength from being in tension!
I guess "terrible" is too strong a term. I guess what I really should say is that its mechanical properties are not as good as other steel alloys, but it does have to be said that its mechanical properties are quite good for its cost. But once you get the copper out of the steel and increase the carbon content to 0.18% (e.g. 1018) then the steel really starts to improve.
rlitman
Long Island
Well according to Wikipedia, ductile iron was patented in 1949, and was discovered in 1943. But nodular iron (aka malleable iron) dates back centuries.
Both are effectively the same end result though, but ductile iron gets there through chemical means, whereas malleable iron starts out as white iron that is transformed through a special heat treatment.
My guess is that many marketing departments use the terms interchangeably, hence the confusion. Glass can be tempered through heat or chemical means too, yet both are simply considered tempered glass.
kwoswalt99
Detroit
I don't know for certain when Wilton made the switch, I can't find many ads or catalogs of theirs.
rumb
Latvia
I prefer HEUER FRONT instead of RIDGID Matador. I Have Heuer FRONT 140mm, RIDGID MATADOR 120 and HEUER PRIMUS 77mm From ~1940. And I love it!
If I buy someday iron vice, it will be Wilton Bullet USA.
snorky18
Southeast Tennessee
GJ spends a lot of time discussing what the "best" tool is, but the burning question in my mind is this:
Has anyone ever broken a vise, or seen one break?
Over the years I've spent time abusing and pounding on whatever vise was available at the time (home/work/family farms/etc), and I've never broken one. (Admittedly I've never explicitly tried to break one.)
johnehr
Oak Grove, Minnesota
Not proud to admit it, but I did break a cast vice some time back, so they are indeed breakable. I was trying to press a u-joint out of a drive shaft by using my vice as a press. It was a relatively inexpensive vice, and I don't do that job like that anymore! Doubtful that a forged vice would have succumbed to my abuse.
NathanJK
I broke a vise, I was calibrating torque settings on my torque wrench by clamping the 1/2 drive part in the side of the vise jaws and hanging weights off of the wrench. I didn’t consider the physics of this operation until AFTER the ****** cheap vise broke. Oh well, lesson learned.
Boilerhouse
Muskoka
I broke a cheap Chinese 4" vise, a friend broke a cheap Chinese 5 inch vise and I saw the broken remains of a Chinese 6 inch rotator type vise at an organization that I volunteer for. So the cheap ones definitely break. I didn't think I abused mine but can't speak for the others though.
If I were in the market, I would look at an older Record vise, older American vise, or a new Yost. For anyone considering the Yost, Lance did a video review.
BikerDad
Utah
I have broken a vise. A 4" 70's vintage Asian import to be exact. Busted the jaw (front or rear, can't remember which) attempting to get a cluster off a bicycle wheel. No cheater, just the leverage one can apply working both sides of a 27" wheel. And no, I wasn't trying to break it. Surprised the heck outta me when it let go....
Lelandwelds
Central Texas
It is pretty easy to ID with a few simple tools: magnet, grinder, torch, scribe, or chemicals. Look for forging excess ground away or where sand molds met.
Many more types of materials. Many more types of metals. Hey, there are many, many diferent types of cast iron.
Files are more than 1% carbon. So are many cutting tools for metal. Modern PM steels can be 2 to 3% carbon.
I try not to use"ductile" in the same sentence as "cast iron". They are almost always in the single digits and can approach zero. Some mfg make up terms like "semi steel" for the ones that are more ductile.
Vises are not intended to take advantage of "ductile". They are a big old lump of "heavy "that doesnt move.
Second, understand that metallurgy and metallurgical science improves over time. Old is only better if it's actually better by virtue of its design.
Steel is hard to DIE CAST. Easy to INVESTMENT CAST. (Which can require little machining or start up costs.)
Yes, what he said. "Most with the least" should be chiseled in stone somewhere. "Vises are not valued for their strength to weight ratio" is hilarious.
Problem with vises is they are a mature industry. Many 50 yo vises are still perfectly serviceable. If they were invented last month, everyone would need one. The quality, price, and selection would be amazing. The "Golden Age of Vises".
tonyciambrone
Northern Illinois
Umm...I doubt a vise like this exists. They make the handle to a length that won't damage the vise. If there is a production vise that the handle can be bent in a spiral and still function I'd like to see it.
