TheEquineFencer
I have a TECO VFD I wired to my Leblond lathe. I set the parameters as required and ran it last night for a while with no problems. Tonight I went to use the lathe and the drive is giving a fault that I cannot figure out what it is. It's a 3HP VFD rated for 1Ph to 3Ph use. FWIW, the first one I got from them was bad right out of the box, it would not power up. This one powered up and worked fine to start with. I set it for a 5 second ramp up/down time at start up.
I tried powering the VFD off and then back on but it still gives a fault.
