The Rusty Gear
I'm moving and my new attached garage has a side entry door which to me is useless and takes up valuable wall space. I'l like to remove the door. Is it as simple as removing the door and frame, putting up a few 2x4's to frame over the hole, then sheath it and install some siding? I will probably have to re-do the siding on that side of the house to avoid a "seam" where the old door was.
What genius though of an extra door? I already have a door into the house, and 10 feet from that door is another door to the back yard. Why the heck would I need to go from the garage to the side yard? To go into the back yard? To save from opening the garage door to go to the driveway (by way of the side yard)
I'm just frustrated because we are downgrading and my "new" garage is smaller (20x22'). They even have the fricking central vac installed in the garage (bye bye another 4 feet of wall space) I think that is going to be removed at the same time as the door - I'm also considering removing the window which has the lovely veiw of the side of my neighbours garage. It's on the same side as the useless door.OK OK done venting.
