My compressor used to trip the breaker. It is a craftsman 33 gallon vertical oilless compressor. I did the recall for the shroud, no change. Verifyed the unloader valve was not the culprit hy bleeding the tank to 0psi. It would intermittently trip the breaker upon startup. I would hear the breaker trip, no noise from the motor really. It was on a dedicated 20 amp ckt with the outlet mounted at the panel. It did do it on the regular garage ckt also. With much research I read of a person in my same situation who had a square D panel. He got a special breaker they offer that was rated HM or high magnetic. It is like a slow blow fuse. I got it at Grainger. It has not tripped the breaker since. If you have a square D panel you are in luck. If not, maybe there is an equivalent in your brand.
