Matco deep impact socket won't fit SO gun
90zcar
I just picked up a couple nice tools at a yard sale and I got a MATCO 1/2" drive 13/16 deep impact socket for .75 cents. I went to put it on my snap on mg725 gun today and it won't slide down on the anvil. All my other 1/2" sockets fit fine. My other brands are snap on,sunex and craftsman.
Funny thing is that it goes on my 1/2" ratchets no problem.
Farthest it goes on the gun
Goes on my ratchet no problem
G1GRANDEUR
did you try to wiggle it little bit? look like deformed.
I don't think you can warranty that, due to grinding marks :)
shockwave
Marietta,ga
Looks like someone has been using as a seal driver try getting a small file and city at the flats on the internal square drive
NeuseRvrRat
yeah, somebody pounded on it with a hammer and then took a grinder to the OD of the drive end to get rid of the mushroom.
90zcar
Damn I never should have bought this!! I'll have to knock on his door and see if he will refund my .75 cents back.
I was wonderinf way the outer edge was all mushroomed
colin39
Man that looks like is been used to beat bearings in and out. And i should know ive used a few OLD sockets for this same method of abuse and punishment. Lol
G_P
Central CT
Seriously your going to ask for your 75 cents back? Lol
This. Just keep it around if you need to use it as a press tool or something. Buying yard sale tools can be a gamble. Losing .75 is nothing to get worked up over.
90zcar
You just need to chamfer the edges of the square drive.
Same principle as redressing a mushroomed chisel or punch.
Makes sense. The ring on the impact anvil probably needs that chamfer to gradually slide in. I'll knock the edges in a little with a file and see what happens
90zcar
Spent a little time and got her to work! Took the file to it and then the dremel with a sandpaper drum attachment to get the center chamfered divots back in. Took my grinder to the outer edge and smoothed the flat with a file.
Works great now
Wamsutta
Amarillo, Texas
Works great now
You did a real good job. And the pride you gain from fixing something is worth more than a replacement socket.
90zcar
Thank you. I figure if I couldn't get it to work after 20some minutes I might consider sending it in for warranty. I don't have a MATCO dealer so sending it in would be my only option. In only deal with a snap on dealer
