Reamer for brake line?
bw77
Upstate NY
Looking for a reamer like this for 3/16 line.
Who makes one?
astroracer
Mid_Michigan
Just curious why you would want to ream a brake line??
After cutting there is generally some swarf or, if using a tubing cutter, the I.D. of the tube is "compressed" a bit into the fluid path through the tube. Reaming the tube I.D. cleans up the swarf and allows the flaring tool to seat properly when doing a flare.
I usually run a drill bit into the end of the tube to clean it up, works well to remove the "compressed" edge also.
I have a couple of the reamers pictured. Once I started using a drill bit I had no need for the reamers. :)
Mark
dlcwent
Member Emeritus
coastal maine
Mark
Thank for the explanation Mark.
I have and old jack knife next to my flare station that I use for that. And only using NiCo line, it does the job well. Something quick and easy.
bw77
Upstate NY
The reviews on that General tool are not good.
I'll try the drill bit and countersink.
Thanks.
GTA Matt
Zebulon, NC
The cheapo brake line cutters at the parts stores usually have a flip out reamer and file on them. The cutter itself is about worthless, but I have one i use just for the reamer.
ConnerSmith
Gilbert, Arizona
I use countersinks a lot for de-burring holes at work. A lot of the guys at work will use file handles to hold the countersink and it makes a nice handle to grip onto.
bw77
Upstate NY
Buy a good pipe cutter most have reamers on them
I have a Ridgid pipe cutter. The reamer fits inside the 3/16 brake tubing,
but it's not sharp enough to remove material.
I used a 1/8" drill bit and a countersink and that worked well.
Thanks for the advice.
cgds92
Raleigh, NC
I used one of these HDX inner/outer reamers when I did NiCop break lines on my Packard:
It worked really nicely.
rsanter
visalia ca
Harbor freight has the hand held chamfering tool that will work. You can also look at
useenco.com. They have them as well
Bob
