I'm in the process of building a new garage on my property. AHJ is me, no inspections required aside from mine and now yours.
Local POCO is going to move my meter location from the side of my house out to the pole by the road. New meter socket will have a 200 amp breaker feeding the house and an additional 100 amp auxiliary breaker which I plan to use to feed the new garage. They will jump out the old meter socket on the house and install a blank cover and use all the existing underground wires for the house feed. New building is 303 feet from the meter pole and I am going to run 4/0 aluminum to account for voltage drop. (I'll need some adapters to fit the 4/0 wire into the 100 amp breaker.) UFER ground embedded in the footer of the new building.
Technically, the new meter panel will become the main and everything hooked up to it down line will be sub panels. As I understand that, it means code requires 4 wire feeds to the house and the new building. It seems that if you take the new breakers (disconnects) out of the equation, it's a service entrance that only requires a 3 wire feed.
As a practical matter, (safety) is there a reason a 3 wire feed won't work or is a bad idea? POCO guy tells me 3 wire is how it's been done for the last 100 years anyway.
