Interesting how you mounted the Eastwood side carry shelves into the inset of the cart. Nice name badge upgrade as well. I did that to my red cart... neighbor gave me the badge.
Nice cart...
Quick question....If I cut the bottom front lip off, how do you think that would effect stability? Thinking of hacking it off and putting a sheet of wood on slides so I can access the stuff better on the bottom. Would loose 3" or so by if I had to put it above the lip.
Thoughts?
Nice job.Goto page 52... I did it... and added a brace. Sucker is solid.
I just had to do it! Don't tell Snap On! HEHE
This is my lawnmower repair cart. I absolutely LOVE IT! I finally can work on things without spreading my tools out on a rough driveway that scratches them up.
looks nice. did you ever think about a piece of stainless or diamond plate on top to use as a work surface? not sure how practical it would be...some guys just have the folding shelves on the sides for work areas
Few guys here in the shop have the same cart so I needed to make mine stand out...
Custom signal green paint job with bedliner drawers, top, side holder, bottom tray and inside of the top compartment.
Custom bent connecting rod and acrylic rod handle.
Custom connecting rod end lid handle with a message to all who try and borrow my tools...
Drawer detail
I plan on ordering a snap on lock to match my big box, the snappy hinges, making full length thick rubber bumpers to the corners to protect the cars I work on, adapting a 12 volt battery, cables and charger for jumpstarting and providing power when programming vehicles, and a set of outlets to charge various tools.
I was running out of room in my big box so this $275 build saved me buying a $10K upgrade tool box.
I remember that post. the op had opened up the area the prybars go through enough so that the handles would drop down lower. then he installed a bracket that was low enough for the handles to rest on ( obviously holes were drilled in the bracket to allow the prybars to pass through ) I thought about doing this but deemed it to much work I added a sunex prybar holder to the side of mine and am very happy with it. I believe I paid 20.00 for the bar holder on amazon.I have read through this whole thread and THOUGHT I saw someone who managed to fit the Cman/Mayhew pry bars into the red cart with some kind of mod. I just got mine and completely forgot that they don't fit properly. Any help would be awesome, I have been going back through but there's a lot of pages.
Thanks in advance.
Thanks in advance.
I have read on it or maybe was an review off HF that red foldering shelf at HF will not fix. As i was looking for the same as i have a double 4cart i stacked together that i wanted to use the shelf to add to.
Sent from my SPH-L720 using Tapatalk
You have the tools, I see no reason why you couldn't make it fit. You may need to drill new holes in either the shelf or the cart.![]()
The 4-Drawer Cart is 16.375" deep and the HF side shelf is just under 18.25" deep. The holes don't line up, but a drill would solve that easily.
I have a pair of the Kobalt sides shelves (from the 2-Drawer cart they cleared out a while back) that are 17.75" deep on my 4-Drawer cart. I just set them flush with the front edge and drilled new holes in the shelves. They hang off the back a bit but haven't been an issue.
~ Carson
Cut the bottom lip off and added a baking pan on sliders. Works great.
Okay that's kind of a slick idea. Oh, and VERY nice bike!!Added a couple lights to the top of my cart. I plan to keep the top open and use the inside of it for more storage so these won't be a problem where they are. Lights are 12 volt but I've got a bunch of different ways to power them and they were only $10 each from Amazon.
Without the lights
With the lights
