Whiskeymike
I'm making aluminum blocks from bar stock, cutting with a bandsaw. The two edges cut with the bandsaw, has blade marks I clean up on a table disc sander. I'm using high quality zirconia sanding discs and it takes about a minute to clean up the edges.
In order to reduce that time as I have a couple thousand to do, I'm thinking about using a routing table, decent sized Bosch router and a straight bit to clean the edges. I'm only looking to take a 32nd or less from the edge. This is strictly cosmetic.
Any tips on the bits I should use? Brand, size, material? Would it make sense to find a finishing mill bit that is side cutting?
The aluminum blocks are 1.5" wide by 1" tall and 1.5" by .5" tall. So I would need a bit about 1.25" of cutting length.
Any tips on how to setup the fence so it cuts relatively straight?
