bagged89s10
It must be worth so much because of the awesome craftsmanship of the included stand. Hahahahahaha lol
One question. Did Wilton's early vises not have handles for the swivel adjustment, or did they have the acorn nuts that are on this one?
Nuts
Reed manufacturing vise 205R. I would bid if the top of the jaws were gouged.
Did you intend to say "Reed manufacturing vise 205R. I would bid if the top of the jaws weren't gouged"?
So I get this call yesterday from my friend Richard.
He says he bought a vise at a yard sale, and was
Wilton one of the brands that I recommended.
He told me there was lots of tools and I should go and
look as the vise was still bolted to the bench.
I go and look and there it was, Wilton 835.
Today he comes by and said come out and look in the pickup.
Was I sure that this was the right brand.
Yep
Where did I want it.
$50, it's good to have friends.
One ear busted off of the swivel, and some chips from the jaws. Dated 6-46
Nuts
It must be "Itty-Bitty Vise Month"...
Vintage Antique Small 2 Size Jaws Jewelers Vise...
On Ebay with $ 9.99 starting bid...
And $ 20.05 shipping...it's in Clare, Michigan...
I'm not bidding on this one, but some of you will...![]()
Exmaxima1. I bet that was originally a bottom, through the bench mount with a stud. The base was drilled and tapped with the machine screw. Is there any sign of a threaded hole under the base ?
It's one of their OLD "automatic" vises. Hold on.....
Edit, file added.
Fireman: it's actually 99's Columbian that he bought, restored and had sitting nicely on the edge of his bench a day later. of course TOP has so many vises hitting the pages that it's easy to assume it's his especially when he posts a comment with another member's vise.
DRIVES Thanks for clearing that up. I don't have one done this week though. Been getting my **** kicked at work and not leaving me any time to play. To answer your question about the Wilton's ...A friend of mine pick them from an unknown source. He has 6 more waiting on me next Saturday. I'm paying 115 each. lil high but he's a good source and he has to make a bit as well. I'll post some picks next Saturday or Sunday of all 10 when I get them . should make for a nice picture
I did a Bad, Baaaaaad thing today.
I picked up this Reed 3C at the FM this morning. You can read the sad tale here.
There's about a 1/2 turn of slop in the handle, but it's smooth enough to turn with 1 finger.
After I cleaned a little of the grime off the slide I noticed that there seems to be some brazing where the slide meets the dynamic jaw, but it was done really well and is only noticeable by the color. It's only on top (you can still see traces of the original black paint on the sides), so I don't think there are any problems to worry about. (last 2 pics)
Both the main handle and the lock handle have a little bend to them. I don't think a BFH will straighten the main handle, as it's 7/8" thick. I guess I'm just going to have to put a shop press on my want list.![]()
The only thing missing is one of the pipe jaw pins. It has a bolt filling the hole right now.
This is one of the early ones of this style. It still has the bulb nose, cast-in jaws, and PAT. PEND. cast into the side.
The newer pug nose models are listed at 120 lbs, but this one weighs in at 112 lbs. So either they got heavier, or my scale is off.![]()
Not only is it a knock off, the dynamic has a crack under the jaw.
That Industrial one? Can't see any crack in the photo. Whereabouts? Only thing I can see is a seam from the casting process.
Bagged,---your Wilton clone looks like a rebranded Taskmaster.---So it would be a clone of a clone.
Now wouldn't it be a clone of a clone of a clone since Wilton is a clone of York?
Scott: it's most likely a Prentiss #20 with a 5 inch wide jaw. it looks like a hunk of the static jaw is missing when i blew it up some, but picture pretty small so getting distorted when it gets close to being able to see it. if you go to the auction measure the jaw width and there should be a # on top of the static jaw just behind the swivel jaw
