How to stop steel tools from rusting?
zurud
I got bunch of hf tools especially pliers that are rusting. I tried wd40, engine oil and bunch of other oil on them but they still rusting. With oil on the tools , they make my toolbox oily... Any other methods I can try. Is brand name like channellock ,knipex will have better product that will not rust and their grip come off?
Matthew3901
Maryland
So what is the humidity like where you store your tools? I had a similar problem where i had my tools in a shed. by adding drawer liners, and dedicate packs I was able to control it some, but I had a terrible time with my tools rusting. I did have some success with PB blaster on a rag.
Sent from my SPH-L710 using Tapatalk
66354dream
Southern California
I think it has to do with the finish that's used, my Snap On pliers have rust stains on them and I live in So Cal yet my channel locks SK and other brands I have are perfectly fine.
iminocca
Orange County, CA
I've been using PB Blaster Corrosion Stop with good results so far. I don't live in and area with excessive humidity so your results may vary...I just spray it on and wipe off the excess, leaves a little bit of a film behind to do the job. I think WD40 makes a similar product too.
Rico.
England
Some manufacturers use a hard wearing varnish on pliers to
rust "proof" them... Maybe worth trying. Just remember to
clean them properly before application.
My cheap pliers seem to hold up ok with oil on them so
I haven't tried the varnish thing.
zkling
Yea, rub in or dip in hot paste wax. Or clear coat them if you really want.
d.mcfarland
Western PA
The HF even in perfect climate controlled environment conditions, will rust. I'm not bashing at all. Honest truth.
nanofrog
FWIW, I found wood boxes help control humidity (I get empty cigar boxes from a local shop).
Fugio
I clean the rust off as much as possible with a wire wheel, chemicals, and anything else I can throw at it.
Once it's all clean I degrease it and spray paint the whole thing with clear enamel. Works like a charm!
Lassen Forge
Once the rust has been electrolyzed off and wire brushed I clear coat mine with Deft clear lacquer (yeah, I know, it says it's a wood finish, so sue me...) - usually about 3-4 coats. Dries really hard and really fast (hell, it's lacquer), other than things like contact surfaces on OE wrenches it's sturdy enough to last... only been using it for a year, but so far so good.
I used to do the enamel thing, it worked about the same, the only thing I didn't like about it was it took longer to dry & cure...at least so where it was hard enough to use. The lacquer is like 5-10 minutes and you're G2G...
G_P
Central CT
This is true. I've noticed that the cheap Chinese tools will rust much faster than quality tools. It must be the composition of the steel they use.
unslow1
Illinois
My Snap-on duckbill pliers rusted faster than anything else I've seen. I live in IL so I have the same problem as OP. I've been wiping my stuff down with air tool oil.
