Sharpening stones
sam.coll
Melbourne, Australia
Hey guys just after some info on sharpening stones for sharpening wood chisels, whats everyone using? diamond or Japanese water stones? which grits? pros/cons of both?
Thanks in advance
lilredex
Toronto
Wet/Dry sandpaper on a flat surface works for me, unless some nails got in the way. Then, a touch up on a disc sander straightens them up.
larryforce
The Norton combination waterstone are a great value. I prefer the naniwa superstores, but I can't justify the cost of a full set
jar944
Northern VA
Thanks in advance
I use both diamond and Japanese water stones. coarse, med and superfine on the diamond then 1000 and 6000 for the water stones.
pendragon1998
NE Georgia
I currently use the scary sharp method, which works well, but I am getting frustrated with dealing with multiple grits of sandpaper and the time it takes. Paul Sellers, a master woodworker, has a few youtube vids showing how he uses a coarse, fine, and superfine diamond stone, followed by a leather strop, and I am planning to transition to that, as he knows what he is talking about. Even at $40-50/stone, it is cheaper than sandpaper long term, but either works fine.
1NRO
oop North
Tried pretty much all of the various stones and without a doubt the sharpest edge comes off a japanese water stone. Method counts for a LOT. It's a simple concept though, two FLAT polished surfaces meeting at a point.
LordPsychon
In your basement...seriously, go look now!
Thanks in advance
What, you guys sharpen your chisels? I just buy new ones when the old ones get dull.;) Seriously though I use diamond stones but I don't do a lot of work with my chisels at the moment so they aren't getting dull. 600 grit is enough for my needs - I would like to get 1200 grit and higher at some point as I upgrade my chisels (using Buck Bros and Kobalts right now, not bad but definitely not the cream of the crop).
Stuey
28m above sea level
Imanishi Stones
4000x and 8000x: 4000x for honing, 8000x for final polish.
Sigma power select 1000x and 3000x: 1000x for primary bevel, 3000x for micro-bevel
King - 4000x for misc honing.
DMT - extra/fine and fine - 600 and 1200 mesh
Continuous coarse 325
Norton stones - 220 and 1000 grit
yodie
I use a falkniven dc520 stone that's a very fine ceramic on one side and a semi fine diamond on the other, finish with a double sided leather strop loaded with white and green pastes. Use this for knives, axes, chisels, my parang and shop scissors that are not riveted. I can get anything to split an arm hair anymore.... Took lots of practice and screwing up, but it's a cinch now.
nicksnothereman
In the Mojave
Thanks in advance
Single edge I'd use an oiled river rock. For real. I use them for machetes (not single edge) and works like a charm. I also use "hunter honers" I picked up from the junk store, very good sharpener. The rock might scratch though and any "smooth" rock will do. I don't know what a japanese water stone is but it's probably very similar to river rock but graded (obviously).
