I'm sure some here are aware of the plasma cutter group buy. Well they are being delivered now. I have received mine and need a plug for it. The specs say 25 amp input. The cord is 3 conductor with marking YC 3X2.5mm2. Pretty small conductors, not quite 12 gauge.
So it has been suggested that I use a 30 amp 230 V plug 6-30P.
That plug is huge for the cord. But seems to be the best available from my research.
There is also a 30 amp "Dryer" plug 10-30 which is what my table saw has on it.
Is a 10-30 appropriate for a tablesaw? Could I also use a 10-30 for my plasma cutter? Or is best practice to use the 6-30 on both? The tablesaw has a nice heavy cord with a molded plug so I'd rather not cot the plug off, but not opposed to that if that is the "right" way to do it. I intend to run a circuit for the plasma to the other side of the shop, so keeping the saw and plasma plugs the same would make sense.
I know that either will work, just not sure which is considered correct.
That lightweight cord is disappointing, but must get the job done. Probably can't push the upper limits of the machine very long.
Exactly! If it came with the cord, why does the OP feel its inadequete? Surely the manu. has tested the unit with the cord it came with!
