FS: Bosch 7" Angle Grinder
jeffhay
Sammamish, WA
Bosch 1873-6-RT 7-Inch Large Angle Grinder w/ 7" Turbo Diamond Cup Grinding Wheel-24 Swirl Segments. $100 plus shipping.
15a 3 HP 6,000 RPM
Also includes Vibration Control Auxiliary Handle, Wheel Guard, Backing Flange & Lock Nut Kit, Hex Key Wrench.
I bought this factory reconditioned tool to grind my 420 sq ft garage floor in preparation for a Wolverine coating. It worked great, but I have no other use for it. I had a Dustie universal shroud on it, but about 2 minutes into the job, I bumped a wall with it, it flexed, and the blade ate it. If you're grinding concrete, I *highly* recommend getting some sort of dust collector for it. But you'd be better off spending the couple extra bucks to get the hard plastic one rather than the rubber universal fit piece. You'll still come out over ~$200 cheaper than the purpose built Bosch concrete grinder.
