Extending a Tap, Any Ideas?
bigcaddy
Orange County/ San Fernando Valley
like the the title says, i need to extend a tap in order to finish a hole in a 6.5" diameter pulley. All of my tap handles, T and bar style, will hit the outer edge before i can even start cutting.
I know i could track down a long tap, i seem to have every size but 1/4"-20, but wanted to see what else could be done to make it work.
Ive checked every socket i have and nothing will secure the square shank tight enough to start cutting. I realize a "quick fix" is not the best way but i've already sunk enough money/time into this project and buying specialized tools isn't on the top of my list right now. I just need to tap the hole before the project gets any bigger:eyecrazy:
Finky198
North East
8pt / double square socket with a long extension and a ratchet if you have a sears they usually stock them a there 2-3 dollars
Davefr
OR
...or a spline socket
However I'd just take a junker socket and grind the I.D. to fit the tap. 5 minutes with a Dremel and carbide burr/cutter.
LXCam
Lisle makes a tap holder kit that the one that fits a 1/4" tap is a 1/4" drive and is not very big in diameter. What's the largest diameter it can be?.
Fretters
South Yorkshire, England
See if you can fit the end in the female end of a 1/4" or 3/8" square drive extension. Even if you need to put a bit of shim in there for packing, it should work fine.
Spudland_Dave
Maine
Put a nut over the end and weld that on. I've got a few like that.
or if you find a nut which is "just close enough" to pass on...you can hammer it on and have a "Hex Drive" tap.. The Maintenance dept where my dad worked did that all the time. I've got a couple taps here setup like that he gave me.
But I agree...Tap Sockets are the ticket here. I use mine all the time. A set of 4/8pt sockets is also handy to have...
arsco
Ma
Most times I can get away with a 1/4" drive extension flipped around
jsaw
Geneva, N.Y.
The tap sockets work well.
Also, they make long length taps called pulley taps. I just found out about them a couple weeks ago.
Shadowdog500
Down the shore
Tap socket will work. But believe it or not they make a "Pulley tap" which is extra long just to overcome the exact problem you are having.
Chris
Steevo
43.49600, -112.04300
1/4-20is such a readily available tap size that you probably have two or three.
Take one and weld a 6" long 1/4-20 bolt to the back of it, so you can turn it with a ratchet and socket, and tap away at your "deep hole"
doan
Frisco, TX
When I was a kid, all of my grandfather's taps had nuts on them. I can't remember if they were welded or just pressed on.
bigcaddy
Pulley tap. Search for that, you should find it.
As I was searching for a solution, I remembered the large shoebox full of taps I purchased from an aviation machinist/engineer. Sure enough, there were pulley taps...in every damn size but 1/4-20. If I ever need to tap a pulley for a Stuart Little's car, I can easily cut threads with my 00-90 pulley tap:lol_hitti
I might buy a few but I don't see myself doing this again anytime soon.
As for having a few "extra" taps around, Steevo? So far the count is: 1 blue point SAE set, 2 ACE sets, metric and SAE, 2 large Plano tackle organizers full, 1 huge shoebox full in their shipping/display boxes and NPT taps up to 6":lol:
One stupid 1/4-20 tap brought all of that crashing down...
If anybody needs a very small tap, send me a PM. I might have it in multiples. I can't think of a better way to use 20 1-72 taps then give them away to somebody who needs them.
mtnwalton
OP doesn't want to buy any "specialized tools", but I would suggest tap extensions - Walton brand
