Shallow or deep, which do you grab first?
fatfillup
Finksburg, Md
When I reach for a socket, I almost always grab a deep socket first. Does not matter drive size or air or manual ratchet, I always seem to grab deep. I think its a clearance issue for my knuckles. That and I don't need an extension. On the other hand, the man who works for me usually grabs a shallow socket and a 6 or 8 inch extension.
What's your preference and why?
Oh, almost forgot, mid length.
skeletonizer
Shallow and a short extension for 3/8 drive. Standard ratchet. My roto has a long *** handle and is not practical in most situations.
I rarely use a ratchet without an extension, only in tight spots.
My thought on the sockets is that the deeps are specialty (relatively) tools and more expensive to replace. 1/2 and 9/16 shallow sockets are consumables. I am in the process of wearing out an old US made Master Mechanic 1/2" 12 pt. I found in a junker. My snappy is for special projects.
jkeyser14
(rural) Maryland
I grab shallow 6 points first. You are less likely to slip off the bolt head using a shallow socket and you are less likely to round the edges off a worn bolt using the 6 point.
Deafautotech
Indianapolis, Indiana
that weird... i am start to grab Raf80 with super short socket that come in with RAF80 kit...
Just kidding!! I always use shallow sockets because right now i am doing most of oil changes...
caper
cape breton
I only use shallows when a deep won't fit.Deeps give more knuckle clearance.Unless it won't fit my first choice is always a bent handle flexhead with a deepwall socket because it can be used like a speeder as well.Bent handle flexhead ratchets don't work particularly well with shallow sockets there's not enough depth to get the handle on a level plane with the nut unless you use an extension.
havi
Northeastern MN
Same reason for me. Short 6 pt. followed by short 12 pt. followed by deep 6 pt. followed by deep 12 pt. In that order to what will work or not.
There are times where I wish I had a medium depth, and have yet to buy some. Maybe next time, lol.
I should point out that everything I wrench on is rusted and at least 30 years old.
quattrojon
England
Shallow 6 point and usually no extension, as i work alot on classic Mini's and there aint much clearance!
rsanter
visalia ca
3/8 drive snap on mid depth 6 point with snap on fixed head ratchet
or
1/4 drive snap on deep 6 point with snap on flex head ratchet
bob
Danglerb
SoCal
I feel lucky when I get the size right before the third try, deep 6 pt maybe more often than shallows. I recently bought the shortest extension, like an inch total, and find that real handy with my flex head 3/8 drive ratchet, but I like a 6" to 8" extension with my PS40 and a shallow socket to see what I am doing better.
Big Bad Jon
I usually grab shallow and an extension on 1/4 and 3/8 for 1/2 I usually grab deep.
