Salt kills weeds better than Round-up (any downside???)
stihlntime
SW Missouri Ozarks
Use Pramitol or Mojave both are ground sterilants will take it to bare dirt for a year. Apply when the forecast is clear of rain so you don't get migration into areas you do not want killed. Blackberries poison ivy brush use Crossbow. These are not restricted in most states.
wdrumheller
Virginia
When I was a kid my Dad told me about this salt treatment, and I made a superconcentrate by heating the salt and water mixture on the stove and then put it in a spray bottle, and he let me loose on thistles in the yard and other weeds. It was effective but also a mess.
Fun for a kid for an hour or two, but now I use roundup sparingly, mowing mostly, and 24d on thistles.
D
drivesitfar
WD: boiling water kills weeds and grass too so you must have had some fun.
SIT: where's the best place to buy those chemicals because i do have some blackberries that need to be gone?
Twisted Sid
CA
ALL: more success. it kills all weeds and once i have the entire gravel area salted i hope to never weed it again.
If thats how much you're suppose to use for weeds, I need to go buy lots more salt. :dunno:
jannan
Because urine has a high amount of Potassium nitrate (aka - Saltpeter), which is a component in making gunpowder. "In the past during times of war people actually collected urine for gunpowder" manufacturers.
:monkey_pi
This statement reminded me of when I was in the AF in the early 60's. The latrines were lined with 30 gallon plastic drums and everyone was instructed to pee in them, instead of the urinals. I can't remember why they were collecting the urine, but I seem to remember it was for a vaccine or something. Anybody remember this, and why they were collecting the urine?????
LifeLongWNYer
South of Rochester, NY
Well, around here, the highway departments dump salt on the roads daily, well almost daily, and it doesn't seem to hurt the roadside vegetation. To give you an idea of how much salt they use, it isn't uncommon to see the salt in the cracks of the pavement way into the summer and early fall.
The grass and weeds start growing as soon as the temperature warms up. I have quite a bit of road frontage and the grass and weeds between the drainage ditch and the edge of the pavement start growing as soon as the temperature warms up. It sure doesn't appear to kill anything.
D
drivesitfar
Life: not sure why the road rock salt doesn't work or maybe it needs to be dry.
ALL: my weeds after 2 days of 90 degrees and no rain. it was 90 degrees last week to and these were thriving and the ones i didn't salt are still green.
not bad results for $5 worth of salt??
PS love the Urine posts, salt of the earth, biblical times and all the other ones too. anybody actually buying a 25 pound bag and using it on their gravel have any results to report?
WhiffySpark
Magnesium/calcium won't do anything to plants. Straight rock salt will
LifeLongWNYer
They use straight rock salt until the temperature gets down to 10 - 12 above zero, then they spray calcium chloride on the salt before they spread it. It makes the salt work well at melting until about -5.
Still, none of that seems to hurt the roadside vegetation. I start mowing the roadside in front of my property at the same time that I start mowing the lawn. It all grows at the same rate.
D
drivesitfar
ALL: in case i forgot to mention or it's buried in the thread i'm buying 25 pound bags of Morton table salt for $5.50 at Costco. it was $4.75 before i started this thread and my neighbors started buying 100 pounds each. i bet the store didn't know what to think of a couple pallets of salt selling out so quickly.
cheers all and i also like a lot of salt on my popcorn, but i think the butter keeps me alive. :bounce:
555
Nomad-Arkansas & Georgia
I'm not debating any of the items used, but here is my experience in the past month. I've been cleaning up overgrowth and weeds from property in Arkansas and Georgia. In particular I've been trying to kill a bunch of poison ivy and poison oak that has taken route do to the unuallly wet summer in both states. I started off with Roundup, switched to the Beyer products when the Roundup proved disappointing and finally mixed a solution of table salt, vinegar and dish detergent. The formula is readily available on the web. It took 3 or more applicatiions of Roundup to just kill the minor weeds and grass, the Ivy just laughed at it even though it stated specifically it would kill poison ivy and oak in 24-48 hours. It didn't do it and I've requested a refund from Roundup. A friend suggested the Beyer products. They worked some better, took a week to turn the poison ivy brown, didn't affect the poison oak and hardly had any effect on the rest of the weeds. I used the entire product making multiple applications per week. The home made stuff worked great. In 24 hours it had killed everything I sprayed. I used this home made salt, vinegar, dish detergent solution a few years back on some fresh cut tree stumps. It stopped regrowth on the stumps and prevented grass growth around them the first year. After that, the grass grew just fine and we even had a "volunteer" tomato plant start in one stump. I'm assuming my mixture and application rate are not enough to prevent future growth. As stated, this is only my experience and not an endorsement for any method.
John
ADSR
Do you think pool salt will work?
44lbs for 8 bucks is why i'm asking.
boobag
go to your local farm/fleet store and buy a jug of Glyphosate. it's essentially roundup without the price. their patent expired.
ADSR
Can't do it. It's illegal here. Plus i'm an organic farm.
D
drivesitfar
555: thanks for the awesome post with methods, plants you were trying to kill or get rid of and the results. there is a solution close to that with the detergent that is supposed to discourage moles, but i ended up using a modified trap to get that pest off my property.
LD: i guess we'll know once you spend $8 and give the pool salt a try on an area away from your crops. please do and let us know. i'm not sure if you have a costco up on the island, but i know Bellingham has one where you can stock up if table salt is expensive in 25 pound bags.
ALL: here's a picture of an area i salted below a block wall next to my driveway and you can see my lawn is sort of green after 3 weeks of 90's temps. the brown spot on my lawn next to the driveway just doesn't get much or hold water hence it being brown.
D
drivesitfar
ALL: better pictures of my driveway and parking strip. weeds are growing, but grass isn't without water so salt is doing it's intended job.
anybody else have any results or pictures to post?
Ed ke6bnl
Agua Dulce, Calif.
I have salty water that is from the water softener discharge that I collected in a 30 gallon container and poured it on weed zero nada but I will try it again.
D
drivesitfar
Ed: from what i'm learning it works better dry. that said you don't see many weeds growing on the beach do you.
thanks for posting your results and let us know if it works next time or try a bag of dry salt and see if that helps.
D
drivesitfar
All: getting ready to put down some more salt on my gravel parking areas and wondering if any of you have any results to report. do you?
rustybutt
Waco, TX
Go to a feed store (if there is one around) and buy a bag of granulated livestock salt. Last I bought in the spring was $4.50 for 50 pounds. I use it for weed control and in the five gallon ice cream/margarita churn. And for any "woody" brush like poison ivy , oak, or even grapevine or honeysuckle, pick up some Crossbow while you are at the feed store. That stuff will even kill mesquite.
boobag
ALL commercial herbicides are salt based. The key active ingredient in Roundup is "IsopropylAmine salt of glyphosate." Add some water and soap (surfactant) and you have Roundup. When you look at the bottle of any herbicide and see the active ingredient ending in "ine" that indicates a "salt" of some sort. The best way to buy a roundup knockoff is to read the ingredients and buy the one with most goodie (active ingredient) for the least amount of money.
http://www.naturescountrystore.com/roundup/page2.html
this. and if you buy the generic glyphosate at a farm and fleet type of store, you pay way less than buying roundup, which is the same thing.
vetron
Idaho
Farmers say use diesel on weeds. Our resident lawn expert says that doesn't get after the seeds. I may try the salt.
Hephaestus29
Indianapolis
The best thing I've seen to stop unwanted growth of weeds or grass is something to block the sun. I know this because where I park my van there is no grass, and no weeds.
TheEquineFencer
Farmville, NC 27828
My neighbor uses crossbow for that.
EricP
Alabama
I can attest to Crossbow being effective on killing poison ivy and other vegetation. It is a 2,4-d and triclopyr cocktail of death for woody vines and unwanted growth. Again, if you want something that stays in the soil and prevents future growth look for Imazapyr on the label.
stihlntime
SW Missouri Ozarks
I went to our local farm herbicide/chemical dealer yesterday. Generic Roundup was 7.00 out the door no tax. I picked up 5 gallons. I also picked up a gallon of Crossbow for 49.99 no tax.You can't beat Crossbow for woody plants like blackberry briers,multi floral rose, poison ivy, or brush.The distributor thought the best ground sterilants were Mojhave which was 59.99 or Pramithol at 41.00. I use Pramithol with a little diesel hasca surfactant and it takes it to bare dirt for 12 to 14 months. It will leach so you must apply when there is no rain in the forecast. If your in a agricultural area bypass the farm stores and locate a chemical wholesaler, the one in our area gladly sells to anyone.
boobag
Well I tried a section of the drive way today with a mix of Diesel and petrol (Gasolene) as I did not have any kerosene. I took to it after spraying it with the blow torch and I guess I will find out in a few days if it worked or not.
well i'm sure it will work, but that is definetly not good for the ground and environment. i hope you dont have a water well.
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
On pretty rocky ground here. The idea is to spray it on and burn it off quickly that way it does not enter the ground. Does change the color of the drive way stone but that will be harrow or raked over later and that will further take away the dead weeds and grass.
D
drivesitfar
ALL: been pretty weed free in the parking area for about a year and looks like I need another bag on it so will do so today and see if it helps again.
anybody else using the salt and having results positive or negative?
Coolabah
2nd Floor, 3rd on the Right,Narooma, Australia
well my 2 cents worth is this : My grandad was a farmer and pretty much all his problem fixes revolved around using what was to hand. So , if someone tells you that farmers use diesel to kill weeds then that is because they have like 100 gallons in their tank near the shed but no weedkiller LOL . Old engine oil to treat wood ? Same, just changed the oil in my tractor, rather than have to take it somewhere I will treat my fenceposts ( not saying this is bad, just sayin') . If I heard someone tell me to start my BBQ with 8 chicken heads and an old tractor spark plug , my guess is that is because that was at hand for some farmer. Pretty sure this is how my grandad did it anyway so ......
Weeds ? Well if you are unable to get enough tractors permanently parked over them then do not use salt. Do not use left over carpet. Pay the $7 for glyphosate ( hey but it also causes cancer apparently ) and spray. Spray regularly and the existing seed will sprout and be killed before they can re-seed. Won't totally nuke and kill your soil like some of these other things suggested. BTW Agent Orange is 2,4,5,T so 2,4, D is not that far away in my uneducated opinion .... why would anyone use such **** ?
/Rant OFF !!!!
