Disney
Is it supposed to make a buzzing/arching sound when power on?
Cool.
I've got 52 cutters awaiting pickup today by UPS.
I have about 2 dozen remaining for the stragglers, two that I've pre-paid for so they can pay via Paypal later (when it clears), 2 warranty extras, and a box of circuit boards....
Look forward to getting the remainder out to the rest of you and hope that the cutters was worth the money and the wait.
Sean
(If that's OK with you shoot me a fast PM with the info, ok?)
I was cutting around 1/8inch with 60psi and 44amp, dont know if that is correct, it was working fine
I could also use use a little more info on that.
Thanks, Sean... I was wondering what was up with that. Maybe I could snail mail you a check, and once it clears you could clear me from Jerry's Kids, er, Special Status to Paid and Done... and get me my cutter! Sure, I can wait for the PP snafu to get turned around, but damn, listening to y'all talk about your cool new toys, well, I'm getting anxious!(If that's OK with you shoot me a fast PM with the info, ok?)
Also - in a way I'm lucky, as y'all are doing the "smoke testing" on these, so when I get mine I can go down the list, make the necessary "corrections", and be G2G!
Sus @ the Forge
I'd be interested if anybody else changed their mind and wants to sell. I can provide a pre paid ship label for you to drop off at a FedEx office.GUY"S, This is with a VERY HEAVY HEART, after all this time, I'm going to sell mine.
The cutter arrived Monday June 29.
Still in the box. Not opened.
If any GJ members are interested in,Ohio, the Southwest quadrant, I would be up to meeting at a halfway point to save on shipping, JUST the cost of what it has cost me, invoicing from AquaMoose .
Now another malfunction, I'm in Georgia now until July 18th, I can't even go and help or look at Kevin's new addition to his garage!!
I'm not keeping this to Ohio members, but it would be easier.
Somehow, let me know after July 20th ?
So is anyone planning on a long extension cord or replace the existing cord with a long one? I am thinking at least 20'.
For people getting an inconsistent arc control, ditch the factory ground clamp, it yielded bad results for me.
I picked up this hobart clone clamp from HF and wow what a difference.
http://www.harborfreight.com/400-amp-welding-ground-clamp-66708.html
I paid via money order and havent heard anything, are there some still waiting to be shipped hopefully?
Cool.
PLEASE do send pictures of bad or questionable connections, faulty wiring, etc to me. I will forward them to the manufacturer. I did speak to them about it (along with a few other issues) and they're asking for pictures. They did tell me that since the last shipment, they have upgraded the torch heads with a new trigger-style type. Made me wonder why they didn't present that option to us then...
Hope everyone's getting their cutters and applying those checks & fixes, especially the plastic sheath that burns easily. Personally, I fired mine up and it gave me no issues but after reading about one member's burnt connection in the torch handle, I took apart mine and saw that there was room for improvement so I tightened the screw and wire tied the tube covering the connector to the main body so it won't slip down and expose the connection. I've yet to put a larger heat shrink tube on it that I have lying around. Next, I'm going to find a leather wrap suggested by Ameshel.
I should add, I want to apologize for getting the cutters out so slow. The manual data entry and triple checking everything made for a slow progress on top of my work/family time. I've learned a lot so no regrets here.
Sean
No, dielectric grease is not the same.So is dielectric grease even slightly compatible with heat sink grease? And where in the hell would a fella find heat sink grease? One set (upper or lower) had the grease marking fairly obviously, the other just looked a little white at the top on the cutter I was sent.
Bill
Bill
