Electrical and waterline
nfk
Kansas
I'm getting ready to run my electrical conduit and water line out to my detached garage. Can I run them both in the same trench? I would put the water line in 3 1/2' deep, partially full the trench, and put the electrical conduit 18" deep. Thanks,
encantofred
Arizona
as far as i know and can tell, the NEC does not prohibit running them in the same trench. local utilities my have different policies, but they will not be involved in running a subpanel feed to your garage.
as a practical measure, your separation of 2 feet is plenty in my mind. i ran my conduit 24" for subpanel feeds, but that was just personal preference.
conduit is not expensive. recommend to oversize it. makes for easier pulling and allows for upgrading if needed later.
tom
Milton Shaw
Put an extra conduit in now while the ditch is open. You might want phone/cable/internet in the garage and now is the time to rough in for it. Even can run an air line back to the house for air use in the house.
joe_padavano
Northern VA
I've done exactly what you propose to do when running water and power to several barns and outbuildings on the farm. Frankly, I've never understood the issue - the electrical wiring will see more water exposure from the groundwater in the soil than anything the water line will cause. If your water line leaks that much, you have a far bigger problem.
Yes, the only issue is if you ever need to dig it up to get to the water line. Be sure to leave lots of slack in the wiring. I always lay a CAUTION tape in the trench above the wire (about a foot or so above, as I backfill) to serve as a warning for future digging.
N
nfk
Kansas
That's the plan, I'm putting a conduit down for cable and Ethernet. The guys at home depot made me out to be the worst person on the world for putting the electrical conduit and water line in the same trench...
Slowgsr
Southern ontario
I ran water, 2 data conduits, hydro (teck cable) and underground plastic natural gas line all in the same trench,
Just please but in the buried cable warning tape
N
nfk
Kansas
I'm using pvc, that's what most around here use for underground service.
ForceFed70
BC, Canada
They let me put electrical and gas in the same trench (2' of separation). Can't see why they wouldn't allow water if they allow gas.
CNGsaves
KS and OK
OP . . your idea of sharing trench likely fine in mild climate Kansas City.
However, curious HOW FAR of a trench are we talking about ?? Having 2 trenches is preferred because it gives you MORE options.
I'd rather share a trench for water at bottom like 36" (for mild KC) and Natural Gas (garage heat) at say 30" depth (with tracer wire so could be located later). In ANOTHER TRENCH I'd share between electrical at bottom 36" and low voltage (CATV, internet, phone, security, etc) at 24" after foot of backfill.
Still would recommend you work up scale drawing on draft paper with whatever you install so you will always know where they are located, without even having to "locate" lines before any future digging you might do. This is important as the 811/DigSafe locate services do NOT mark homeowner buried utility lines.
N
nfk
Kansas
I'm only going to have the electrical above the water line for about 30', then the electrical goes off in its own trench. I am planning on burying caution tape with everything.
P Dubya
Iowa
I've buried miles of water line and electrical line in the same ditch. The power for every well has to get there somehow and around here they go in the same ditch.... One thing I do not agree with is the separation at different levels in the ditch. If you ever have to dig down to the water line to make a repair you do not want to have to avoid the electrical above the water... If you feel they need to be separated do it by placing them on opposite sides of the ditch.....
N
nfk
Kansas
I got the trench dug this weekend and put in the PVC and tested overnight, not just need to finish up the ends of the electrical run
LX-Markham
Markham, Ont.
Same here, ran power, gas, and water in the same trench. Ran the water line in a conduit in case I ever need to replace it.
wes73
South Central PA
I ran water, electric, phone, cable and ethernet in the same trench. I ran 3/4" PEX for water sleeved in 2" conduit. This was at 40". Back filled 2'. Ran another 2" conduit for electric. Back filled 6". Then ran 1-1/2" for the Cable, Phone and ethernet. All of this was 120' run and roughed in inside the building before the floor was poured. The inspectors for both eletric and final never asked about the trench, what was in it or and seperations.
