Digital Angle Gauge
Tim37
I was looking at those I think it would be real handy but the tolerances are a little loose for my liking. If you can be happy with +-1° I think it would be great
larry_g
oregon
A friend brought one of those over and we could not make it repeatable. It had some 3-5 degrees of hysteresis. He sent it back. I'm sure there are some good ones out there but the little block style like that he had was not acceptable for the work we were doing.
To check it one of the things I did was stick it to a leg of a precision square on the granite surface plate and zero it out. Then rotate the square 90* so the other leg was on the granite to see if it would read 90* It was within a degree or two but when rotated back and it should have read 0 but it was off some. So if you get one check that it does what it is supposed to do.
lg
no neat sig line
exmaxima1
Midwest
The name says it all, what's you input on this ?
I was considering this little guy: http://www.axminster.co.uk/gemred-digital-bevel-box
However, I'm open to any suggestion if you guys use anything better / more accurate.
Cheers,
Hem
I use a similar model with my homemade knife sharpener to set the bevel angles. I zero it on the blade and then adjust the "stones" to the desired angle. Much easier than calculating or using a protractor.
Sal Bandini
Accuracy is 0.1, not 1.
It looks like my Wixey gauge and mine is repeatable. You aren't going to get any more accurate than that plus that price is about what the other brands go for.
Tim37
I will have to do more research I though I had read 1° i could live with .1° for a lot of things
larry_g
oregon
The add says RESOLUTION is .1 degree. That has nothing to do with accuracy or repeatability. And I said in my above post the one I had hands on was not near +/- 1 degree. The one I had hands on was a different brand.
lg
no neat sig line
A_Pmech
IL
What do you want to do with it?
A Hilger & Watts vernier clinometer can be had inexpensively if you watch Ebay regularly.
Colin Len
Long Beach CA
Looks like a neat little gauge, I haven't seen small ones like that before. We started using these years ago for work - we used them for determining things like roof pitch. We don't need them to be super accurate though for most things.
More recently I added one to a cheap level I cut to size so that I could measure my own camber and help do my own alignments at home. Worked great even if it was a bit ghetto looking.
Sal Bandini
lg
no neat sig line
True, I didn't read correctly.
However, my Wixey gauge looks exactly like that with resolution of 0.1 and accuracy of 0.2. It is very repeatable as I check various angles it returns to zero at my reference every time.
http://www.wixey.com/anglegauge/#wr300type2
H
hemdale
France
Hi Woody73,
Sorry I haven't replied sooner. Starrett products aren't that easy to find in Paris but I think I'll go for the inclinometer from CMT. Give 2 secs to find the link [emoji2]
Envoyé de mon iPhone en utilisant Tapatalk
toddoky
Bowling Green, Kentucky
My Go-to angle measuring device is now my iPhone with the clinometer app, it is as accurate as any other angle device I've used, is backlit and provides audible results as well as visual.
Ign
Butte Peak ND
I've got the Craftsman level w built in angle gage...mine is roughly 12" long. I'd say its readily repeatable within .2 and if you let it sit for 5-10 seconds almost always within .1.
It shows the temperature when you first turn it on, always found that odd and yet somewhat useful, or at least informative.
