Above 1200 Sq/FT 86's 20HP shop
drivesitfar
86: nice paint job on those old racks and not easy to extend them with stuff on the one next to it. nice work.
can i offer a suggestion? if you have an extra beam can you put one under the window about 3 or 4 foot from the floor. you might want to build a bench out of shelf and all you'll have to do is put a beam in front or maybe you'll need another shelf. at the very least it will help support your tall racks since your first shelf is up about 6 feet from the floor.
looking good and keep up the great progress. :thumbup:
jbmatth
Northern Ok.
I do agree the RAS would be quicker for the repetitive cuts, but if you have a miter saw you could always mount it on some plywood or osb then build a stop out of scrap 2x4 screw that to the plywood or osb as well and your set. I've done this many times and it makes it much easier with those repetitive cuts.
JB
86turbodsl
Dont have a miter anymore. It was junk anyway. Plus not many miters can cut 2x12s.
Sent from my SGH-T889 using Tapatalk
86turbodsl
Ok, so some major progress last night. I said the heck with waiting, and we installed racking all the way to the end. I used two beams as spacers for the 3rd section, and only installed them temporarily so i can pull the outer beam out and allow the drywall lift to get all the way to the wall to finish ceiling steel. Then the rack to the right of that, the 4th section, will be holding motorcycle parts. There are a SIGNIFICANT amount of MC parts sitting on the floor, so putting that up clears a lot more floor space.
I still have to cut boards for shelves and then that can happen. The area below the shelves will form a dedicated MC workbench and storage area for helmets, boots, tools, and work surface for things like engine rebuilds and such. Keeping it dedicated on many of these workbenches will allow for multiple projects to be ongoing without having to clean up a single workbench each time. I have been plagued with multiple long term work projects that don't finish quickly and tend to crowd each other.
And the pics:
86turbodsl
Well, saturday was family reunion, so nothing happened but today after a bit of recovery time, we got some more shelving up. My "little guy" was helping this time. Good thing he's so tall, he was able to hand totes up.
We put the 3 shelf beams up, then cut up the 2x12's and installed them. We attached the uprights to the wall also.
A couple more stacks of stuff off the floor. Room to start moving things around for the steel install.
86turbodsl
No pic to show, but last night moved the steel stack do i can start ceiling again. Open floor is probably 20x20ft.
Sent from my SM-N910T using Tapatalk
Strouty
Southern Maine
Nice! I have been working on my air compressor and that will free up some space when I get it put back together. Keep up the progress you are motivating me.
egnorant
East Texas
How have I missed this!?! It seem I have found another eclectic project magnate!
I too have Escorts, 60s Fords and have stuff that finds me no matter how I hide. My organization is better but I still accumulate faster than I dispose of stuff.
Of course I am many miles away (Texas).
Bruce
86turbodsl
Bruce
Ummm, you weren't paying attention? :headscrat
Just pokin' you.
Nice to meet you! I should go around and take pictures of all the "projects". It would blow your mind.
Hello from Michigan. I wish i lived in Texas. My bro lives in DFW area. I miss him.
Show me your garage! Would love to see it.
86turbodsl
With all this discussion of projects, i thought i might post up on that a bit tonight.
tonights project: Rebuild the stuff wrong with my drywall lift. I have been having trouble with it loaded up, since it's a cheap chinese lift, stuff isn't built real well. One of the pulleys hogged out it's mount and i fixed that for starters tonight.
The mount used to be a pulley on a tiny little 3/8" pin and a bushing way too big for the hole in the pulley. I replaced that with a 1/2" bolt and a bronze bushing greased up and bolted through.
the hole was hogged out from the pin spinning, so i drilled it out to 1/2" and tacked washers as bearing surface for the bolt.
The next problem was the force of the cable pulled on the plate with the crank and reel/drum off center, which bent the plate it's mounted to. It's a crappy design really, so i bent it back to straight and welded a reaction plate to it to keep it from bending again.
Finished that, and primed everything. I'll put it back together tonight and use it tomorrow.
86turbodsl
And since i am thought to be a project hound, i'll go through what's on the plate right now.
Suzuki GS1000 i bought to part out. Paid $400 and made several times that on the stuff sold. Still have the chassis and lots of parts left.
96 KTM Lc4 400. Bought this non-running, got it running, then the stator died. Common problem on these. Been working to revise the charging and starting system, wanted to design a chain drive electric starter, but found a cheap stator and will probably just put it back together and ride it.
Suzuki GS850. My main street bike. Blew the base gasket last year, haven't had time to touch it. Painted everything while apart, seat is getting a cover made. A good bike, but not real fast. I want to sell and buy a 1st gen Vmax.
67 Fairlane convertible. Bought in Plano, dragged it 1000 miles behind the 86. Bought because it's intact minus powertrain, and factory AC car. Very rare.
Bridgeport mill. Series 1, variable speed head, bought from a shop in Wixom, $400. Complete with DRO, but no scales, in really good shape. 42" table.
Head needs a couple parts. Seller told me to let him know what i needed, he would replace no charge. I didn't have the heart to follow up at this price.
1920s Crescent 24" planer. Beautiful machine, replaces my 11" Yager.
Beach 1" spindle shaper, and to the right, a 16" Rockwell RAS frame. It's parts are scattered about. I needed to disassemble it to get it into the shop. Probably acquired at the worst of the clutter.
This shows the tops for the shaper and the jointer.
67 Fairlane coupe. Owned this since i was 16. My first car. Restored once about 28 years ago, 351W, J302 heads, torquer 2, toploader, 9". VERY fast car.
Oil boiler used for heat.
Runs the infloor tubing. Waste oil conversion, but it doesn't work right, boiler is too shallow.
Waste oil filtering setup i built. Works great, but WVO is way too hard to get these days, will probably scrap it and just go waste motor oil exclusive.
The $150 air compressor, 1960's Curtis 10HP, D97 pump, what started the whole 50HP phase converter project.
Had leaky disc valves, and sloppy primary piston. I'm working on it occasionally.
NP205 onto a diesel ZF5 transmission. I've been playing with this idea for a while, in search of truly bulletproof but retaining mileage. The IDI diesels really don't like RPMS too much. I have some ideas for fixing the cracking tailshaft problem that's common on these that may be patentable.
My little guy's XR250R that needs a tuneup.
the yanmar GT14 diesel lawnmower that i bought for $850 that needs the crankshaft nose straightened. It tossed the PTO driveshaft before i bought it, and i didn't catch it before purchase. Inspect your stuff !
97 F250 PSD, bought with bad flexplate for $1500, and ended up ruining the ****** due to bad circumstances (long story)
Picked up a E4OD to fix for $300.
8' Boss Vplow, purchased with problems for $400, currently working on fixing, probably won't put it on the F250, planning to fix up the F250 as best as possible, and purchase a F350 CC PSD somewhere in Texas and 4wd conversion. have a D60 already.
There's probably others i'm forgetting. But that should entertain for now... LOL.
Strouty
Southern Maine
Some good ones, but like me you have too many! Do you get bored easily? Seems like I will be hot to trot on something then it just goes cold.
86turbodsl
I do have too many projects. Trying to pare them down. I don't really get bored with them, i just have too many and limited time and funds to finish things. I guess i see some things as being easy to fix, then get into it and find it's tougher or there's some problem that's going to cost more to fix. Then it sits while i wait for money or time to work on it.
I'm very good at finding projects, not very good at getting rid of them.
egnorant
East Texas
Just click on the link below! My hoard shrunk by 2 cars last month. Sold a 1965 Ford crewcab and a 1971 Mustang...but...this month I added 2 1964 Rancheros, a 67 Mustang coupe, 70 Cougar convertible and a 72 Cougar convertible and associated parts. Yes, they were screaming deals and I could not resist.
I took down my 4x8 shelves as they became catchalls in the shop. I chose to make my shop a WORK area and storage was elsewhere. I am down to only 3 motorcycles and will update my garage stuff this weekend.
Bruce
Fast914
Dartmouth, Nova Scotia Canada
86, thanks so much for this thread....lots of great ideas and we all suffer from the Organization thing....you have done amazing work and on top of that built your house too....sheeesh!
Those cabinets you were speaking of at #135....you can find them at your local Hospital...they are constantly renovating and this stuff often goes out to the dumpster...I know I know...but most will offer old furniture and cabinets to Staff etc for minimal monies....its dramatically less expensive for them as they actually get a little cash money for them but more significantly they don't have to pay for disposal transport etc.
These cabinets are often used to house Blood Slides from the lab...and will have two drawers side by side or as in your example one broad drawer...they are great for fasteners or whatever...I have all of my drawers labelled...just thought I would hopefully add a little to the conversation. Regards, Grant
86turbodsl
Nice idea, yes, i agree with you, pallet racking may look too industrial in an attached house garage. Luckily, my shop is a separate building with more of a farm outbuilding motif, so i can get away with a lot. The house garage is mostly for parking. Maybe sometime i'll show the house on the thread.
86turbodsl
Grant, Thank you and you are welcome sir! The cabinet drawers were Drivesitfar's idea. I still am not 100% sold on it, i'd have to look at some in person and see if they would work. I think there might be a place i could put some like that, and it would save building separation into the storage. I'm hoping all my little part storage can be built into my workbench drawers but these might be a fast way to do that. Not sure, jury's out.
Strouty
Southern Maine
I am starting to see that getting rid of a few lets me finish some of the others and once you start finishing, it is a huge deal. That tends to create more momentum and more cleaning and more finishing. Almost like a never ending cycle, but in the right direction. I still have plenty of projects that should go, but I can't let them just yet, my brain says I didn't give them enough time yet. It does take way more will power to cut a project loose than than to keep it on the back burner, once it is gone, it frees you up mentally as well.
I find it amazing how much the physical "stuff" truly effects your mental "stuff".
Strouty
Southern Maine
Strouty, agree 100%. It is hard though.
The biggest problem that I have is when I jump from project to project I tend to lose parts that are key elements of the projects. I am crazy disorganized in that way and then the project can get halted because I become a lunatic looking for the thing I know I bought. I probably spend 50% of my time doing **** like that, I want to get better. :eyecrazy:
86turbodsl
LOL. I solved that one thanks to my neighbor. He gave me a pile of these blue plastic totes that were meant to hold machined parts from workstation to workstation. You can see a few in some of my photos. They hold parts securely and don't deform. YOu can stack them too. I probably have 30 of them. They work good.
Edit: There's one on the back of the GS850 and one on top of my spare powerstroke engine in the crescent planer pic.
bulletpruf
San Antonio
Great thread! Love the Fairlanes! My 66 GT convt is pictured below. 500 hp stealthy 428 (looks like stock 390), toploader 4 sp, just finished 2 years ago right before I went to Korea. Still have to install the new Magnum 500's and BFG redlines, restored grille, red rocker stripe (matches red interior).
What are the plans for the 67 'vert? How solid is it? Good floorboards, cowl, etc?
Scott
86turbodsl
Nice 66. Black is tough to pull off. Tentative plans for the convertible are restomod, family cruiser. 5.0 EFI/or variant, AOD, luxurious as i can make it top down/summer cruiser. Car was a texas car, found in a field, rotten top. It has bad floors. Everything else seems to be solid, haven't been far enough into the body to check cowl. All there, intact glass, etc. Some issues with the top mechanism, so i got a spare. MANUAL top, with AC, radio delete i think. Super weird combo. Converting to power top. I *MAY* get to it in my lifetime. I bought it sight unseen, based on price and location and options. It was less than a 1000.
My other one is also a rare one. 289/c4/factory ac/radio delete 500 coupe. Only 8000 ever made. Restored in 88-ish, turned from gramma car into firebreather. WAS about 500hp, have since de-tuned to to be more sane on the street. It was just too much before.
bulletpruf
San Antonio
Sounds like a good plan on your convertible. Fuel injection, overdrive, disk brakes, and A/C would make a great driver. Right now my 'vert has a big Holley dp, manual trans, manual drum brakes all the way around, manual steering. Not much of a cruiser, I guess.
My 'vert needed lots of bodywork, too. If I had to do it again, I would have gone with the original color - bronze.
Let me know if you need parts. I have lots of leftovers in my storage unit, including some of the hard to find convertible parts.
See below for a pic of my old firebreather - 67 500, another super clean and solid Grandma car. Came out of the Seattle area; had been garaged its whole life. Started out 289/C4, replaced with 796 hp 514/built C4/minitub, etc. Big solid roller and 13:1 compression was too much for the street. Sold it a few years ago.
Ok, sorry for the hijack. Back to the build!
egnorant
East Texas
Cool! I find convertibles tough sometimes, but I just bought 2 Cougar convertibles, 1 1970 and a 72. This is in addition to a 70 and a 69 Mustang convertible. I found a friend about 2 years ago when I drove down a street and saw a 67 Fairlane convertible in a garage. I just stopped and started talking!
He had been searching for a GT grill for a while and I just happen to know a guy less than 4 mile away.
He helped me develop another of my useful mantras..."So, what are you doing right now?" He was talking about how things would progress once he got the engine in and those words just popped out!
2 hours later we had his engine in place.
Bruce
86turbodsl
Some days we just need a day off. Dont feel bad. Rest is important too.
86turbodsl
Bullet, that is a beautiful 67. I bet it was a handful. Ill keep u in mind if i need parts. The coupes original color was sauterne gold. Was that your color?
bulletpruf
San Antonio
Yep. It certainly was beautiful and also a handful. To do it over again, I would have built a strong stroker pump gas Windsor for it (if I get it back that's what I'll build for it). The 385 series engines are just a bit too wide for shock tower cars unless you convert to Mustang II front suspension and get rid of the shock towers.
My convt was Emberglo Metallic with Emberglo interior. Good looking color but would have looked better with black interior, I think.
Scott
