balane
Zkling, that looks really good I think. Amazing work especially considering what you had to work with. Do you have the slide support chunk?
sorry i was referring to the width. i want a really good vise that i can "pass on to the grandkids"
my question on the newer wiltons like the 500s or the 450s are they still considered to be the last vise i will need assuming that i take care of it which i will? i can spend whatever i need to(within reason) to get a top of the line vise that i will have forever. are the new ones going to give me that or do i take forever to find a restored used one?
thanks again for all of the input fellas
On top of that the PO decided it would be a good idea to test out his sand blaster on the sides giving a pretty rough surface.
It's not pretty seeing blasted cast, is it. It removes a lot of the natural look, in my opinion. That battered, blue Parkinson I got a while ago had received that treatment, and you can tell the difference in surface appearance straight away.
It is amazing that can happen to a 2" vise. Just like the one with chips I bought recently. What are these people doing with these tiny hobby/jeweler vises? A hammer should never come anywhere near these things. I can see a guy using one to hold his work while he swaps out some old, rusted tie-rod ends and then wonder what went wrong.
Personally, I'd suggest keeping your eye out for an old vice in good physical condition. Doesn't need to be restored, as long as it's physically sound. A quick tart up doesn't take long, and can be anything from a quick degrease and clean to a full strip and repaint.
Is there any way to share PDF files on here? The forum software has a stupidly low file size limit for them. I have a Parkinson Vise catalogue that a friend kindly scanned for me and said I could share.
EDIT: Fretters has kindly offered to sort a download link for mebl00 also offered to help out so I'm grateful to them both for helping
Thank you sir![]()
Fretters: thanks for posting the link to the catalog and it works for me. it must be fairly large because it took a while to download or my old laptop is slow.
have you seen a Parkinson Ball Vice in person or owned one?
CW: thanks for finding the Parkinson catalog and probably should ask you too if you have or have seen a ball vice?
happy to hear you finally have a vise that you can pound on because it was built for that.
No problem.The thanks are owed to you though, not I, for making it available for the rest of us.
Does that link work okay, btw? My browser decided to play silly beggars a while ago, so it took me a while to post that link.
Fretters:
Your link worked great in allowing the download of the .pdf
BTW, the Parkinsons riggers vises are amazing.
Mike
zkling,
The slide on my No. 21 ( 3 1\4" jaws ) is 1 3\8" wide. The slide support is 1 7\8" long from the base. Maybe this will give you a guess as to the size on your No. 19
Nope, right up there with rounding over corners, holes and polishing uneven surfaces.
Congrats on the complete post vise.
the tough part is that i dont see alot of used around here and im just afraid that there may be some hidden issues if i get one...plus my o.c.d. wont let me have a vise that doesnt look good on my bench, but thats my issue..lol
i have some other projects that i would like to spend my time on and leave the vise restoration up the guys who have done several
I'd probably look at a Yost combination or a Wilton tradesman for a general use.
are you referring to new ones? or going with one of these to have restored?
if you are referring to getting used ones are there any really good new vises out there if i want to spend the money. it seems that the general consensus is that all of the new vises of any brand arent as good as older used ones. do you concur?
So, this is the process and I'm happy with the outcome. It now works again. Result!
Really enjoyed the process of ripping it apart, cleaning it up and repainting. I know the handle is still beat up but I like that character about it. Been through the wars. Probably literally as I'm unsure if he age.
I don't mind a "patina", especially for vises that get hard use, but I don't think I could tolerate a bent handle like that. The handle is your interface with the vise, and it should be as close to original as practical. YMMV....
Paint job looks fantastic!
I've very little use for the Paramo currently as I picked up another record for a good price. If I decide to do a bit more work with it then it may drive me crazy and I'll need to straighten it out.
Might need to make myself a Rail Road anvil first. [emoji3]
These are the images the other vice. It's a Record No. 34.
Richey, those vices look great.
I've some Record love of my own to add: my brother spotted this No. 1 in an antiques place the other day and picked it for me for £13. It's a little smaller than I'd like at 75mm jaw width but at £13 I'm not complaining! I'll pick up a No. 6 or similar at some point into the future.
I've given it a clean with a rag and white spirit to remove any grease and oil. I'll probably paint it soon: is it best to strip off the good blue paint or can I leave it and paint over it? I assume a primer is a good idea.
The jaw screws came loose without a fight, which was nice, and there's no significant wear/abuse on it.
Edit: its weight is 5kg.
