Killed a ratchet today
Squ1d
Maybe not completely dead but out of commission for a while at least.
I know I was using it improperly, way too much force for a 1/4" ratchet but it was the only tool that could reach in on a Muranos Transfer Case fill plug.
I tried an offset box wrench, ratchet wrench, 3/8" low profile ratchet and nothing else could get on the plug and still have enough clearance to turn.
2 hours later I've got a busted ratchet and a stripped plug. Gonna have to pay the dummy tax on this one.
oldldh
Fairhope, AL
"Damn, I shouldn't have done that!!!"...Is a great teacher...:sad:
I know...
In my multitude of years...
"OOPS!!!"...Has taught me a bunch of lessons...:mad:
Don't worry...
There will me many more...:evil:
mrjaw14
Nashville, TN
I'd say a 1/4 or 3/8 breaker bar was in order, but if the 3/8 wouldn't have fit, the 1/4" breaker bar would have failed too assuming that your ratchet didn't have a hairline crack in it to start with. That's interesting it failed right at the retention ball, but looking at it that area does seem to be a weak point. looking at the angle of the break I take it you may not have been straight on the fastener and coming at an angle? at least you went for the gold, I'd have used a beater ratchet and probably ended up in worse shape
ARFLY
NW Arkansas
When they let go that bad, its usually not just the ratchet that is busted. How bad are your knuckles busted from that one?
organ
Atlanta
Look at the difference in the grain of the metal...
BDT/NWMN
Erskine, Mn
You were naughty today.. Your turn to sit in the corner..
I don't care for that excessive recess on the drive end of a socket, either.. I would rather have a smaller recess and more contact with the square ratchet drive. Some of my newer Craftsman sockets with the double detent also have horrible contact when used with a SnapOn or Proto ratchet. Worth checking out....
Might want to round up some heavier artillery for battling that nasty plug.. Leather gloves will help when duking it out.. Show that ****** who is the boss..
Bigblue&Goldie
That Dual 80 (72) mechanism is pretty damn strong! I have a small BluePoint breaker bar for these situations.
BK13
PDX, OR
Probably wouldn't have mattered, what with where it broke.
Bigblue&Goldie
No doubt, but it keeps my ratchet in service. It's also easier to keep the socket on the fastener square with a breaker bar than a flex head when you are applying a lot of force.
BK13
PDX, OR
Wait, you don't have backup ratchets for your backup ratchets?
PFSard
Mesa, AZ
I'm dying to hear the solution to negotiate the plug without destroying (temporarily) that beautiful ratchet.
Squ1d
Yes it was a snap on. Knuckles are intact. 3/8 breaker bar could not fit with short 3/8 drive socket.
Like I said. A short 1/4" drive socket with 1/4 ratchet was the only thing short enough to get on the plug.
Something that ratchets was needed. I only had a few degrees of movement allowed.
A ratcheting wrench was too thick. There was another bolt right next to the plug.
I have a low profile 3/8" ratchet that fit but the handle was too fat to get a cheater bar on. (It had a cushioned grip)
Squ1d
I didn't. It's still in there. The one smart moment I had that day was to try to take the fill plug off before taking the drain plug off and emptying the transfer case.
I rounded it off a bit too with the low profile 3/8" socket. I'm gonna have to take it to a garage. They may have to remove some sections of the exhaust to get at it.
Codyyy
It looks like it would have damaged the swivel section but I'm assuming it is designed so the ratchet breaks at that point instead of the swivel area. I have an old S-K 3/8 swivel ratchet that I put a cheater bar on and ended up bending the handle itself. I ended up beating it back straight with a hammer but I guess I learned that no matter where a breaker bar is, it is worth taking the time to find it instead of using a ratchet.
Indexmill
Central NC
I never really thought about how much of the meat is whittled away for the ball and spring. Has to be enough to reduce its strength vs. no ball and spring. Obviously, it's not normally an issue; just interesting to observe and think about.
BK13
PDX, OR
I wonder if the long, double ended 1/4"3/8" HF rat would have fit....
(And yes, I hate to be that guy)
Squ1d
Sad thing is I have one of these but completely forgot about it. It's in a different drawer then all my other ratchets. And yes. It probably would have fit.
mrjaw14
Nashville, TN
You're talking about this right? i was at harbor freight yesterday and was looking at that ratchet and every one I've tried the mechanism feels horrible. you guys doing anything to make it usable?
ARFLY
NW Arkansas
I look at those every time I'm in HF. Looks like it would good for reaching really tight spots.
BK13
PDX, OR
I look at them too. I just can't bring myself to drop $30 on a ratchet from HF. I did get a couple of the shorter ones, one for me, one for my six year old son's box.
Squ1d
That's the one.
Try multiple ratchets on the rack. Some might be better than others.
It, like many others are something you might not use often but are very thankful to have it when you do need it.
Had I remembered that I owned it the other day I probably would have not broken my snap on ratchet. Or, I might have broken this one, cursed it for being a harbor freight piece of sh*t, and then broke my snap on ratchet.
stage20
pcola FL
ive got a couple short and the long flex version of that harbor freight ratchet. they work really well, but i do have older versions of them. ive beat on them pretty good and they may break tomorrow, but they are nice for certain jobs
