New Harbor Freight composite ratchets
kctyphoon
Jersey/Staten Island
i was holding these the other day.. they look nice, feel nice to hold.. i can see these becoming more popular than the other composites for the longer handles..
ARFLY
NW Arkansas
I look at the composite ratchet every time I go in there. I guess I will have to get one to try.
Youngguns
Mtns of Western Maryland
I've had the 3/8" ratchet for a while. It has been my go-to ratchet ever since. I picked up the 1/4" ratchet not too long ago to go with. It's every bit as alluring as the 3/8". Still debating on that 1/2". I'd like the set, but I'm not really a 1/2" kind of guy.
ER70S-2
I just bought the 1/4" and 3/8" for around $11 each with a 20% off coupon. Make sure you play with all of them in the store and buy the ones that feel the best. The ratcheting mechanism sounds/feels different between all of them. Most even sound different depending on whether it's ratcheting right or left.
When you get them home, take them apart and clean the internals. You will see that it is almost completely dry inside. It's scary to think that some people probably use them like this. Inspect the gear and remove any burrs you see. I ran a razor blade through suspect grooves to feel for them. Finally, lube every moving part sparingly with something. I noticed a huge difference in sound when using a moderate amount of lube vs a small amount of lube. I used Super Lube. If you use too much, the ratchet gets an imprecise sound and feels "mushy". I like positive clicks. Positive clicks probably means that the pawls are making good contact with the gear. Finally, use Loctite on the screws and adjust the tension on the selector. I also put a little lube under the head of the selector screw since it rotates when you move the selector and a drop of oil in the quick release mechanism. These things sound and feel so good once lubed they make my brand new 88-tooth Armstrong MAXX ratchet sound like it's full of gravel. I'm not kidding.
valentine
Kudos to Harbor Freight for offering some really good products at affordable prices. Overall, HF is really making great strides in improving the quality of their offerings.
-Valentine
thebeekeeper1
Illinois
-Valentine
Agreed. The last two years have seen great strides in the right direction, which is really welcome given the fact Sears/Craftsman has gone off the cliff. :(
MrBreeze
Scottsdale, AZ
Interesting.
Are you guys using these instead of your steel ratchets, or in addition to?
What is your main motivator to switch to a composite? lighter weight, non conducting, less prone to ding/dent/scratch material near by, or something else?
HotFry
Arizona
I was kinda wondering what the allure was myself (not bashing truly curious).
I probably have five sets of all the ratchet sizes so every time I see them i just think to myself "Another ratchet is the last tool you need dummy".
firworks
IL
Interesting.
Internally, they are very similar to other "conventonal" ratchets, they just have a composite coating to provide temperature and electrical insulation, and prevent damaging your work. I think someone tore down one of these or a Tekton and it was basically a normal ratchet with an overmold.
Kin Creed
Minneapolis, MN
Pretty much all of the Pittsburgh Pro ratchets are better than Craftsman. The swivel heads in addition to the composites. I like the swivel heads also.
The composites are lighter and much better in cold weather since they don't freeze your hands. They are just all around more comfortable and feel more solid with less play and slop.
I also have too many ratchets, but the HF ratchets are nicer and I actually look for reasons to use them! Using a good tool is good for you garage soul I suppose.
hancock1701
Orange, CA
Those look pretty nice. I can't stand using my klunky Craftsman ratchet handles anyomore, the HF ratchets are so much nicer.
The same reason I decided to abandon my Craftsman ratchet and make those HF ratchets my go-to's. They're so much better, and affordable. But I just got some Tekton low profile ratchets, so I need to find myself an excuse to get these.
ER70S-2
Those Tektons look sweet and appear to have the same internals as the HFs, but a little more expensive. Do you know where I can check them out in person?
MoparTrucks
Ozarks of Missouri
As an older guy with arthritis starting to cause me great pain I have found that the composite ratchets are just easier for me to grip and use. I have the older HF composites with the shorter and thicker handle and I use mine all the time.
They are hard to clean though and mine look pretty grubby most of the time.
hancock1701
Orange, CA
Here's the thread discussing those Tektons with pictures.
http://www.garagejournal.com/forum/showthread.php?t=294474&highlight=tekton+low+profile
Home Depot has those for sale with "purchase online, pick up in store" option. I'm sure you can order them and play with them while picking up. If you don't like them, I guess you can return them right away (or maybe come back the next day ?!).
TheOtherChris
SE Idaho
I have had a full set of USA Craftsman for years.
I tried the HF 3/8 composite and thought "Wow" Why didn't I get one of these years ago?
It is more comfortable in my hand. My old fingers don't hurt after hard use. It is a LOT nicer to use up here in the North where the cold of the steel penetrates gloves pretty fast.
I think I will pick up the 1/4 and 1/2 in the next couple of weeks.
kctyphoon
it really is comical - that if these same ratchets and sockets were sold under a different name, with "made in the usa" stamped on them, they would likely be the most popular hand tools on this forum.
i think i recently paid 6 or $7 for a SET of 1/4" drive deep SAE sockets..
