Lately I've been engaged in a Craftsman teardrop ratchet type study, focusing on those made between approximately 1956 and 1993. Based on my best research to date, the 3/8" drive bearing model #43785, came with at least two different manufacturer's codes (-V- and -VV-). The earliest #43785 also had two U.S. patent numbers, and one Canadian patent number on its handle with a -V- manufacturer's code. The second generation #43785 no longer had the patent info but retained the -V- code. My information at this point may or may not be completely accurate, but I believe the third generation #43795 was produced with a -VV- manufacturer's code. The age of your ratchet can be approximately determined by the stuff cast onto its handle. Generally speaking, I believe the #43785 was offered by Craftsman between 1967 and 1979. All three generations of the #43785 that I've observed have an oil/lubrication hole on the top of their heads, a metal long lever selector, the quick release feature, and "flat top" or barn style letter "A"s in the word Craftsman. It was also the first Craftsman 3/8" drive teardrop ratchet to have its model cast onto the handle. In terms of value, the #43785 is relatively inexpensive. Their average selling price on Ebay is about $10 - $15 give or take. As far as I can tell, the most commonly seen version of #43785 is the second one as described above, with the -V- code and no patent info.
So there you have it.... I'm not 100% sure about all the facts and figures stated above, but I feel like it's relatively accurate. If anyone reading this has any constructive suggestions, additional info, corrections, etc. I'd really appreciate hearing from you. I'm trying to fine tune my Craftsman teardrop ratchet type study. The more information I have the better the information I can spit back out in threads like this one.
Jim C.
