crankshaftdan II
Cabin well pump (drilled w/220volt sumersible) flipped on the breaker, pump started rightup ran for long time, could hear water entering old pressure tank. pump finally shut off, opened sillcock and water flowed fine for about 10 minutes, gradually slowed down to nada! pump kept running, shut off sillcock, no water pressure! The pressure tank does not leak, and has no bladder, just trapped air in dome of tank. Q?? Does this sound like a pressure switch problem or maybe low water in conjunction with the pump being to high in the casing-sometype of venting of the pressure tank? Don't use this well much and don't have much well knowledge!! Any comments or suggestions would be appreciated.
Many thanks for all the teriffic information! ,Cranky
