Drill Press tables. Slot type differences?
uart
Australia
Looking at small cheap drill presses, I notice that there are two popular styles of slots in the tables. There's the "X" (radial) type as shown in the first attachment, and also the straight (parallel) type as shown in the second attachment.
I'm just wondering what particular advantages/disadvantages each type has. Can anyone comment on which style they prefer and why?
Thanks. :)
Dennis Leigh Henry
South Central, IN USA
The slots parallel to the column make it easy to add a fence that can be adjusted back / front fairly easily when doing semi production hole drilling in furring strips and the like.. I rarely use the slots on my SBL drill press, it has the criss-cross slots, which are also useful as shown..
U
uart
Australia
Thanks Dennis. Just wondering, can most drill press vises mount ok to either type?
BD1
north side
Many tables rotate so you can use whichever slots it has. There are a few different clamps available too.
I know you said cheap and bench , but check craigs list for one. There can be some super deals on floor models. They buy them and just sit on floor with little use, get in the way, and then sell them. If doing metal work a slow speed is nice with a three pulley system instead of just a front and rear setup.
U
uart
Australia
At the moment I'm not looking for another DP. Just curious about the two different styles of table slots and wondering what the advantages of each are. :)
U
uart
Australia
Hi Dennis. Just wondering what that orange clamp that you've got there in the photo is called. Is it an off the shelf item or is it something that you modified for purpose?
Dennis Leigh Henry
Generally speaking yes..with the right bolt or nut, it is usually a breeze..
I don't always clamp to the slots anyway.. Sometimes I simply use a C Clamp..
Dennis Leigh Henry
Special purpose commercially available "hold down" clamp. This one is a Jorgensen 1623.. McMaster Carr catalog snip posted below shows something similar. I've seen these with Vise Grip style locking mechanisms, and with Kant Twist as well..the McMaster catalog page will show the others as well.. :rocker:
U
uart
Australia
Thanks Dennis.
Actually that looks like something I could rough up pretty easily from one of the beat up old G-clamps I've got here. You're giving me ideas now. :)
