Called on a $100 Wilton C2 today, already sold though.
Thanks Get and Ziggy. Good to see that they bolt on, have nightmares about that.
I want to mention that if you have a shot at a Reed 4C and the swivel lock downs are missing remember one thing, they are a precision clamp system and not easy to make. It was like building a mold again. Reed uses a double lock, one side has teeth at a 30 degree angle and a back 30 degree angle to really lock down the clamp. I made a couple sets just this once and do not plan to make any more. I have a drawing if anyone wants one.
Too bad. I don't mean to rub it in, but look what I got for only $55!
[/URL][/IMG]![]()
I'll give you $60 for it. A quick $5.
I'll go $65.
$70 and not a penny more
Unless someone overbids me.![]()
Ah, Reverend Scott of the Church of the Flying Chips---
Pretty fancy steel whittlin', there Bubba!!!
I would say that the Reed method of clamping the swivelin' bit down, might be the most "Positive Locking Mechanism" I've seen...
With both of them clamped down tight...
It's...
Almost...
A...
Non-Swivlin' B@#tard!!!![]()
The old Prentiss "plunger pins from hell" would give it a run for its money. Nothing more solid than a rod in a hole.![]()
That's a bit strong for a can of WD40 .... [emoji14]Too bad. I don't mean to rub it in, but look what I got for only $55!
[/URL][/IMG]![]()
Kevin,
Precision work as always. Did you weld in threaded inserts?
Well, it is a steel can . . .That's a bit strong for a can of WD40 .... [emoji14]
Pretty fancy steel whittlin', there Bubba!!!![]()
You gotta be kidding. $20. You really ****Got it! A Milhoff double swivel! This morning at an estate sale for $20. It will be my next resto
[/URL][/IMG]![]()
[/URL][/IMG]![]()
That sums it up nicely.Damn fine deal and a good vice you got there, MBS.
MBS, a big Wilton for $55.00, and a Milhoff for $20.00. Really?---Now this has got to stop, or as Old says, "ve vill have you shot".![]()
Yes, that is usually how things work.He won't see another vise for months. That's the way it works at least in my case.
MBS, enjoy it right now because those kind of deals come few and far between.
Made some jaw covers out of UHMW and teak. Pressed in some rare earth magnets covered in superglue.
Ultra high molecular weight polyethylene. Tough and soft.
Unless you Joestriper. Then deals just follow you home.
