SO MG725 disassembly
Rosso
Scotland, UK
Hi,
I'm needing some help getting my MG725 stripped.
I've got as far as removing the back plate and taking out the rotor.
The forward/reverse lever, grip, top grip and end plate are all stripped
I need to get the hammer mechanism out of the main magnesium housing.
Anyone know how on earth it's fitted ? No visible method of holding it, guess it's pressed in ?
country83
Put the back of the housing where the motor came out of down flat on your workbench and smack the end of the anvil with a soft faced hammer (not a brass one, that'll damage the anvil). That should pop everything out, hammers, anvil, front plate, everything.
stikman56
If that fails, ( it should'nt) turn it anvil up and tap the back edge of the housing and the cylinder and end plate should inch their way out with every tap.
R
Rosso
Scotland, UK
Thanks folks. Work great.
Any one ever rebuilt one ? What did you use to lube the hammer mechanism and bearings ?
country83
Front bearing and impact assembly get Redline oil, rear bearing gets regular grease.
