Wera screwdrivers differences?
Altec
SoCo, MD
The stainless is only good for working with stainless hardware. That would be my last addition...
The Lasertip is a all around general driver set. My first choice...
The Chiseldrivers are good for more abuse. Prying, hammers, and other misuse. First choice if you are hard on screwdrivers. Although I prefer just to keep some old Craftsman screwdrivers around for that...
AutomatiquE
France
Stainless Steel Wera drivers are for sensitive industries, such as food industry, Nasa... : No rust tips, always clean. Generaly speaking, stainless steel tools are more fragile and have a limited torque. They're not destinated for a general use as mechanic or houseworks, so...forget them.
Others Wera's, those with a Green handle and "lasertips" are perfect for a general use. The Yellow handles are similar to the previous but with a shaft running trough the handle and a striking cap. They're also known as "chiseldrivers".
SoulDe
Panamá
Thanks. I'll buy Wera Kraftform Plus – Series 300 for routine works that does not require using the screwdriver as a chisel.
Kielbasavw
Southern California
Figured I'd ask here instead of making a new thread. Do the yellow handle drivers have the Lazer tip too? I want to be able to pull my tool box around the shop by 1 Philips ;)
Monte
Germany
No.
Lasertips will also wear faster....
Negen
Seatltle WA
These are my favorite but are probably new from old stock as they have been updated.
The newer ones have 1/4" square in the striking cap.
Wera 932/6
932 S/6
The 3334/6 are stainless and I guess might be nice to have if you have issues with rust.
The Wera Kraftform Plus 334/6 are the laser tips which cut into the fastener to give extra grip.
