Crimping Tool For Battery Cables
trackwelder
n.y
Yesterday I had to repair a six gauge battery cable on the riding mower and did a terrible job trying to solder it. I have never been any good at soldering ends on cables and always make a mess. I'm am looking for crimpers for 6 gauge and larger wires. I would like a pair that can crimp cables in place and for bench work as well.
I want to buy something to last so quality is a must. Any suggestions would be appreciated.
Kielbasavw
Southern California
Trick.... Flux the cable and inside connector. Cut pieces of solder drop into connector. Hold with pliers, heat connector till solder melts, then stick cable in. Works everytime.
pete379
x2 did this many times -- first time making battery cables for a class 8 truck !
organ
Atlanta
What kind of terminals? Ring? Those are easy to solder! If you want to use a crimper under the hood you're probably gonna want a hydraulic one... and those ain't cheap.
Brownsfan
Cleveland Ohio
Sine Swept
I got the same one. It works best if you use the same wire / lugs consistently so you get the best fit on your connections. I use the closed ended lugs covered with some heat shrink.
T
trackwelder
n.y
kunkernator
US of A
I just ordered one. Still looking for a crimper that can be used on the job in a engine compartment . Back to searching, thanks.
Glad I could help somewhat. As for tight quarter, I would listen to the other guys, I dont have much advice on those.
Bigblue&Goldie
This really is the easiest way. I use a pair of locking pliers to hold the lug. Fill lug with solder, Flux the cable, use a torch to heat the lug until the solder melts, hold the cable in the lug until the solder hardens. It will wick solder up into the cable, so I don't typically tin the cable. I do Anderson connector lugs the same way.
Bigblue&Goldie
Never solder. Proper crimping, alone, is the preferred method for reliability.
The hydraulic crimper shown previously will do the best job for the money. An Amp crimper like mine now costs ~$700. The hammer-one is the least reliable.
Here is a good how-to.
http://www.pbase.com/mainecruising/battery_cables&page=2
I generally agree, but for a lawnmower or other non-critical application soldering is perfectly acceptable.
Spudland_Dave
Maine
Really? I was always taught that Crimping was the cheap/half *** way out (only surpassed by the "bolt on type), and Solder or Compression Type was the Correct, preferred way to do a quality terminal.
I was gonna reply...the correct tool here it to order an assortment of Solder Slugs...correctly sized slugs with the proper amount of solder for a given wire size.
Not saying your wrong ez-duzit...this just went against everything I ever heard... now I need to educate myself on this further when time allows... :headscrat
mg283680
Electrical connections should never use flux. Fact.
Also, even if soldering a joint should be crimped. You need a mechanical bond since solder has no strength.
bob15
Northeasten, CT
Crimp the cable first....then solder, with no flux. You should be using Rosin Core solder.
This works well for heating larger terminals:
This small Smith brand silversmith set works even better for heating:
firworks
IL
You definitely need flux. It's just important not to leave it all over everything and clean it up properly. Without flux you would likely not even be able to get the wire to bond to the connector or the solder. That's why most solder has a flux core such as Rosin. However, if you leave flux residue on the wire or connector it can cause corrosion which is why if you use flux paste / liquid flux rather than a flux cored solder, it should be cleaned afterwards. For a lawn mower that sits in non controlled environments all year it probably doesn't matter. There are much bigger issues that will cause failure long before the flux, but for more delicate / important jobs it can make a difference.
