Kellyblues
Chicago electric TIG welder. Definitely pass. Had mine for close to 4 years and it's been perfect.
How are the harbor freight wooden work benches? Decent enough for a Vice?
Sent from my Nexus 7 using Tapatalk
6 Pc Pipe Tap & Die Set
Item# 91395
$14.99
This is one of those items that get both a Pass and a Fail.
The Pass - The Taps and Dies work well and are surprisingly sturdy, and the set is a fraction of the cost of just one piece from a name brand.
The Fail - They're oddly sized and won't fit standard tap handles or die holders. You will need to be creative to use them. I ended up using a 3/8dr t-bar and 8pt sockets to drive the tap that I needed to use. It was a little loose, but got the job done.
http://m.harborfreight.com/12Volt-150-PSI-Compact-Air-Compressor-69285.htmlpittsburgh air compressor = FAIL
http://www.harborfreight.com/12v-100-psi-high-volume-air-compressor-69284.html
bought it to use when my power tank runs out (which always happens halfway through airing up) and didnt' expect quick, but after 15+ minutes if it went up at all, it was maybe 1psi
Chicago electric 5 amp Orbital Jig Saw Item 69582 - FAIL
http://www.harborfreight.com/5-amp-heavy-duty-tool-free-variable-speed-orbital-jig-saw-69582.html
The bit clamp on this twists up about 10 degrees resulting in the blade being turned at an angle and making straight cuts nearly impossible.
How's the one from Drill Master?
I have the drill master one I needed for a quick project, with 20% coupon and sale price I think I paid about $15 out the door
http://www.harborfreight.com/32-amp-variable-speed-jig-saw-62405.html
I've abused it since and like most cheap HF power tools if it does the job I bought it for I consider every other successful use icing on the cake!
This is the one the rock crawlers like that is competitive with the mv50. I have two that I used for a few years back when I had 35s. I used it for a short while with my 40s, but now I just use a belt driven compressor.
my mv50 only lasted two times too![]()
Axle bearing puller set #66380 Fail X2
I bought this set and went to pull the axle bearings out of a Ford 8.8 axle. The first set had the threads come out of the puller before the bearing started to move.
Exchanged that set for another and the threads held but the puller piece snapped in half. I ended up running a steel bar through the entire housing and tapped the bearing out.
I bought the 2 ton cherry picker which seems like a bargain at $179 to me and I am giving it a pass.
I've had one of these fir years and it's a trooper. Even backed over it with the car and it still works great.HF 3 gal., 1/3hp, 100 psig pancake compressor = PASS
I wanted a small portable air compressor to use with my trim & finish nail guns (NOT HF!) to install door casing, window trim, baseboards and shoe moulding in a new room addition on my house. Saw this HF pancake compressor, with coupon, for $49 and thought it was worth a try.
It's pretty noisy, but it worked great for my one-off job. Probably not enough pressure for a framing nailer, but OK for trim work.
I've used these countless times with a slide hammer and have had zero issues. What method did you use to pull the bearings
Does anyone have a opinion on the 3100 PSI, 2.8 GPM, 6.5 HP Pressure Washer they have on sale now? My wife is wanting one and I was curious if anyone had one. I did a search here and the motor seems to get high marks here at GJ but what about the entire pressure washer. Before I sink that cash I was curious on how good it is.? Here is a link.
http://www.harborfreight.com/3100-psi-28-gpm-65-hp-212cc-pressure-washer-epa-iii-62200.html
I'm curious about this pressure washer as well. I'm assuming the motor is good, but the pump is the typical consumer grade junk...(like my 2100 psi unit with a great 4.5 Honda engine...and shot pump...).
Sent from my SAMSUNG-SM-N910A using Tapatalk
I had the version before this model.
I didn't buy it, it was given to me.
the engine ran great and the pressure washer worked fine for about 6 months, then it just quit, no more pressure.
I didn't know the history on it or how old it was. it seems to be like every other home owner quality machine, the engine will outlast the pump. I had a Honda powered one also and the pump went out on that one also.
