Hello,
I've read many of the posts on this topic, I'd just like some details for my specific situation.
An electrician will be making the connections. I'm doing the prep work and getting the materials.
The house has 100A service panel in basement. Distance from main panel location to nearest wall of shed =51ft. Wiring will exit the house in the joist bay next to the main panel. Total wire length should be <65ft total.
I do not plan to run a welder, electric heat or A/C in the shed. I need sufficient power for table saw/miter saw with shop vac, interior lighting, LED cans in the soffit, low voltage landscape lights, stereo and maybe a small fridge.
What I think I need is a dedicated circuit in the main panel, #10 THWN(?) with ground wire in 3/4" schedule 80 PVC, buried 18" deep, to a sub-panel in the shed.
Any input would be appreciated.
Is #10 wire sufficient?
What size breaker is recommended for the main panel?
Grounding rod needed at shed?
Photos:
1) main panel with (6) available slots.
2) Distance from meter/main panel to shed. I intend to trench along perimeter of patio then angle-off to the shed, as shown.
Photos:
