Timing belts aren't that difficult to do. Attempt to get a PDF copy of dealer manual online or can try library. Be sure to properly time the cams and crank prior to removal of belt. I always replace water pump, idlers and tensioner. They're are two types of tensioners and one is better than the one they, however most cars come with the pin grenade type that are prone to leak. Last year I did my brothers timing belt on his Mitsibushi Galant. That motor had an access hole in front of block that you had to time correctly and put a screw driver in it to stop the balance shaft from turning. I had to get it exact cause if not you'll have vibration at higher rpm. I also have the special tool and pic below:
Last year did my Honda Ridgeline timing belt:
Hardest part was crank bolt, only cause it was 6 weeks after my partial neprectomy and I used the Honda special crank tool and large breaker bar w cheater.
Easier job was last weekend on a 2006 Suburu Forester. That timing belt was even easier than my Honda. Bolster motors are a bit more forgiving cause when timed it is at mid stroke and not top dead center so don't have to worry as much as a cam moving and valves meeting top of piston like other engines.
Old parts in this pic. Replaced all idlers because they had unusual marks on surface of idlers, replaced water pump and thermostat also. Performed combustion leak test on block and no head gasket leaks, which immon with these boxster engines.
Video of Suburu Forrester up and running. Filling coolant level and purging/burping block of all air. Be sure to do this so you don't overheat your engine with an air pocket.
Take your time and clean the block really well with brake cleaner and mark all the timing marks clearly. If cam locks are needed or wedge tool, be sure to use them. Inspect rubber seals to timing cover, which are mostly plastic covers now, for wear and cracks. Replace since you don't want debris in there. After timing belt reinstalled I always turn it at least 2 or more revelations to ensure that all timing marks realign. I also mark the belt to the orientation of the cam timing marks and crank and count teeth and mark reference point to new timin belt. This ensures your not off a tooth on reinstall. Some belts require taking slack out of them and proper orientation, normally left to right on install of belt, then check marks and pull grenade pin to tensioner assembly.
On some, I was unable to get an impact or budge crank bolt and resorted to the breaker bar on crank bolt, pull ignition coil wire to ensure engine wouldn't fire and give the starter a quick tap to free crank bolt. That's my last resort on stubborn bolts and don't recommend it if you've never done it before. Think it's snapon or MAC that makes a special crank bolt socket that makes taking crank bolts off easier with impact.
A decent 3/8 and 1/2 torque wrench comes in handy. My 1/2 tech torque wrench does not do some lower torques so I defer to the 3/8.
