WilltheEngineer
I bought several of the red handled Tekton pliers, and thought I'd go over the good and bad.
The Good: Groove & Slip Joint
-The Quality of these, is very good, Made in the USA, tight joint for both the groove & slip joint pliers, and good metal on both.
-A raised surface area (see picture) helps reduce frictional surface area on the slip joint.
The Bad: All the other pliers (Long Noise, Lineman, Fence, etc..)
-No to little cross tread/teeth on the jaws (one sided on the Long noise).
-Metal flash in the joint, even after cleaning/breaking off, preventing full closure.
-Cutter on pliers not ground to an edge (sharp).
-Cutter edge on angle cutters, over lap, and offset.
-Bad finish grinding work, almost completely off to one side on the fencing pliers.
