Hi,
So I am in the process of obtaining a warehouse-type building to convert into a garage. Here are the details:
The building is Pre-constructed metal walls, with a metal roof, and three garage doors on one side. There are no windows, and there is a side door on one side for entering/exiting the warehouse.
The total space is about 1,900 sq. ft, and the walls are 12 ft. high.
The flooring is concrete without a basement. On the inside the walls are insulated.
Currently, there is only electricity going to the garage which has been mostly used for overhead fluorescent lights. There is no A/C, heater, ventilation!
My goal is to convert this into a car storage garage and possibly a workspace to be used for repairing cars/etc.
This is located in the northeast so in the winter the place gets around freezing (or slightly below) and in the summer the biggest issue is high humidity and lack of ventilation.
Can you guys recommend a way to set this up? I was thinking that A/C is not feasible since it's a lot of volume to be taken care of (23,000 cu. ft.) and it would not be economically feasible.
One thought I had was to have a cut-out in one of the walls (somewhere close to the ceiling) and adding an industrial-type fan that blows outside-air inward (doing it the other way - blowing air outside) has the issue that dust from outside would accumulate through the doors/cracks/etc.
This would provide ventilation but not air conditioning for any vehicles to be stored here/etc.
Any other thoughts? Ideally I'd like a solution that allows:
(1) ventilation when nobody is present;
(2) control of humidity to a threshold that's acceptable for storing vehicles;
(3) some form of air conditioning (on demand?);
(4) heating for the winter.
This is a huge wish list and I'm sure $$$, so at the least I'd like a way to have ventilation and some form of humidity control.
Thanks!
Thanks!
