What is this pipe and can I move it?
Fatgeekyman
Setting up a laundry area and there is a large iron pipe that has been capped. My guess is that it is sewer? It is in the way of putting my washer/dryer in the preferred location. Wondering if it is possible/recommended to recess it back towards the wall?
cowboy73
southern Indiana
You probably could eliminate it. It likely part of the vent stack as large as it is. The real way to tell would be tear out the drywall to see what is really behind it.
8man
Bryan, Texas
Looks like an old cast iron sewer pipe to me. You should be able to remove it, so long as it is capped.
Cyberbear
California
This looks like an identical situation I once had. The large pipe was the drain for the washing machine, and I did recess this drain and capped it to prevent serer gasses from entering the living space.
LS6 Tommy
Northern NJ
If that sink drain is 1-1/2" you're going to need to use that capped off cleanout. Your washer has to drain into a 2" minimum.
Tommy
gregtwojeeps
Ky
The way my old eyes are seeing it, the chrome hose bibs and the sloped 2 in. drain pipe under them ...are for his existing washer. I agree with the others, the 3 in. is probably a cheaper version installed of a 3 in. clean out. jmo
sixty4
CT
Looks like someone had roughed out for a sink at one point. I would be more concerned with the gas line open ended, plugs are cheap insurance.
pmiranda
Austin, TX
Looks like a cleanout. I'd trim it back closer to the wall and put an easy-to-use cap on it.
Actually I'd open the drywall, verify that opinion, cut it back inside the wall and bring a plastic end out maybe 1" proud of the wall with a plastic screw-in plug so anybody could use it in the future. I'd also want to put in new ball valve shutoffs and a nicer washer drain.
brownbagg
sewer cleanout. just make it come out the other side of the wall, out side. there no water in it
IronMyno
Definitely vent pipe
Sent from my LG-D801 using Tapatalk
