Any 120v Electric Heaters Worth a D#$n?
nealric
It's only September, and it's still 90 degrees during the day here in Houston, but I'm beginning to think about heat options for my detached 2-car garage (slightly oversized). The garage is work space for my Alfa Romeo and also has a home gym (daily drivers get the carport). I would heat the garage for a few hours a week at most. It's rarely below 45 degrees or so- but just cold enough to be uncomfortable.
I noticed that most garage heaters, if electric, run 220v. I suppose I could run a 220v line, but my heat needs are pretty modest. Would one of the cheaper 120v units do the trick?
I would also like to avoid gas, since there i no easy way of running a gas line to the garage and I don't want to deal with more gas refills.
ripperd
Twin Cities, MN
Insulated? How well?
If its not insulated 20a 120v is likely not going to be able to supply enough heat to do a whole lot. Even so it will probably take a long time to warm up.
N
nealric
Not insulated, and I don't really want to go there as there just isn't enough time when it's necessary to heat. And doing more research, I agree. Seems like the solution is to install a 220v outlet.
Falcon67
Merkel, TX
120V heaters don't do much, just current limited. They can only pump so many watts into the device. Having lived in Houston, I can see you firing it up when the winter winds chill the air to a frigid 50F. ;) Really, the 240V heater I use works very well. Running a 240V line is a pain, but for the ease of use when you need it, it'll be worth it IMHO. On those few days you need it, it'll get you comfy quick.
motofool33
Currently North of Houston
little big heat, sold at rv stores would do the job. i have one im in spring you could come check it out if you like they are small but pack a punch.
used one to heat my 40ft motorhome last winter when everything was frozen
Stuart in MN
Minneapolis
If you're looking for one that plugs into a regular 120vac outlet, the best you can do is 1500 watts. There's no need to go for expensive ones, the cheapest 1500 watt heater will do just as well - look for what is commonly called a milkhouse heater (so named because they were designed for use in milkhouses on dairy farms.)
Depending on how well your garage is sealed up and insulated, a couple of them may be enough to take the edge off. A couple years ago my furnace broke down on a -20 F January night; I rounded up a half dozen space heaters from my neighbors, and even with a big old drafty 100 year old house I was able to keep the temp inside at 55 degrees. You'll have to look at doing a heat loss calculation to find out just how much heat you need.
People will mention that electric heat is generally pretty expensive, but if you're only heating for a few hours now and then it's not that big a deal.
theoldwizard1
SE MI
Go deluxe ! Install a mini-split heat pump.
(To answer your question, most 120V heater will roast your ankles when you place them next to you or raise the temp a couple degrees after an hour at best in typical 2 car garage. But boy can they make your meter spin !)
jkwilson
SW Indiana
The problem with heating a typical garage infrequently is the common lack of insulation and the enormous thermal mass of the concrete floor that really makes a heater work hard when first raising the temperature. That means you may want a bigger heater for your use than you'd need for constant heating.
Showkey
"MEMBER EMERITUS"
Wausau WI
He does not want to spring for a 220v heater .........don't think a mini split is in his budget :dunno::dunno::dunno:
stihlntime
SW Missouri Ozarks
1500 hundred Watts is what you are limited to on a 110 volt heater. The old cheap milk house style heater will do as well as anything. The infra red eden pure style heaters do a good job in a small area. I would bite the bullet and run a 220 as suggested.
