motofool33
So I've noticed that my new hydraulic hose from my compressor to my tank is getting quite hot and it's starting to swell under pressure. Pics attached
So what I want to do is make a copper line with compression fittings and local available copper line.
I'm going to make a new line from 2nd stage head and in here I plan to put in a intercooler/after cooler before the tank.
So as I understand it to use 1/2 pipe I need to use 5/8 compression fittings. I went to home depot today and they had very limited stock of these fittings only had 5/8 comp to 1/2npt. One side I have 3/4" compressor head. The check valve is 1/2npt.
So where do you guys get your fittings I started looking at grainger. Just wanted to make sure I'm supposed to use a 5/8 compression fitting on 1/2 npt npt copper tube.
And for the copper I'm looking for the flexible L or M but homedepot only had rigid straight pipe in stock any help here is appreciated also.
Sent from my SAMSUNG-SM-G900A using Tapatalk
