Lowe's Clearance Thread 2015
Status
Not open for further replies.
Spn1025
New Hampshire
hmm same store that had the $10 pump yesterday is showing it today for $4.98. ordered it again.. don't have my phone on me so don't know if I got a cancellation. Order status online still shows "processing". I'm gonna swing by after work anyway.
Spn1025
New Hampshire
Looks like they are replacing the duo fast line with dewalt. These are closing out
Sent from my SAMSUNG-SGH-I337 using Tapatalk
I remember seeing a bunch of Duo-fast on clearance, but now it shows nothing in stock at every store around here on the website. I know they still have some.. I'll have to check in-store prices.
kneeman
Doesn't show online but still in stores at different prices.
06GMC5.3L
Just placed an online order for some of those extensions etc. Prices were slightly different, but...
Thanks SPN!
GasEngineer
Northern VA
If you get those 1/4" extensions, be careful when pulling the plastic tag off. The plastic tip got stuck in the end of the three that I got and were an PITA to pull them out.
The lock button is a bit clumsy, but the extensions are decent overall. They are worth it at the clearance price.
Spn1025
New Hampshire
do a search for "kobalt extension", filter for "in store only" then sort by price.
there's a bunch of locking extensions and wobble extensions showing 40-60% off.
06GMC5.3L
1/4 is the only size I didn't get.
Spn1025
New Hampshire
I think they had a better deal on this before.. something like $30 or $40.. but anyway, this is still a good deal.
PORTER-CABLE 3-Amp Oscillating Tool Kit
Item #: 591294 | Model #: PCE606KT16
$49, was $99
http://www.lowes.com/pd_591294-70-P...06&Ns=p_product_price|1&pl=1&Ntt=porter+cable
Also, this is better than the cheap Skil and Black&Decker mini screw guns:
PORTER-CABLE Lithium Ion (Li-ion) Cordless Screwdriver
Item #: 538776 | Model #: PCC842L
$23.99 was $49.98
http://www.lowes.com/pd_538776-3425...81&Ns=p_product_price|1&pl=1&Ntt=porter+cable
Spn1025
New Hampshire
Spn1025
New Hampshire
Check your local prices on these if you want them, they may be cheaper than I'm seeing.
Kobalt 1/8-in to 5/8-in Copper Tube Cutter
Item #: 150860 | Model #: 55295
$4.89
Was: $6.98
Save 30% thru 10/26/2015
http://www.lowes.com/pd_150860-2136...Id=4084144&Ns=p_product_price|1&pl=1&Ntt=hose
Kobalt 1/8-in to 7/8-in OD Copper Tube Cutter
Item #: 150931 | Model #: 55294
$6.59
Was: $9.42
http://www.lowes.com/pd_150931-2136...Id=4084146&Ns=p_product_price|1&pl=1&Ntt=hose
Kobalt 1/8-in to 1-1/8-in Copper Tube Cutter
Item #: 150933 | Model #: 55293
$8.72
Was: $12.46
http://www.lowes.com/pd_150933-2136...Id=4084148&Ns=p_product_price|1&pl=1&Ntt=hose
Kobalt 1/8-in to 1-1/8-in OD Copper Tube Cutter
Item #: 131848 | Model #: 55296
$9.44
Was: $13.48
http://www.lowes.com/pd_131848-2136...Id=4084030&Ns=p_product_price|1&pl=1&Ntt=hose
Kobalt 1-1/2-in Poly Tube Cutter
Item #: 150944 | Model #: 55298
$10.14
Was: $14.48
http://www.lowes.com/pd_150944-2136...Id=4084154&Ns=p_product_price|1&pl=1&Ntt=hose
unslow1
Illinois
Thanks for the heads up. I've been wanting the locking extensions for a while. I wasn't willing to pay what they were asking. While I was there picking those up they marked down a lot of the spline sockets. A couple of cheaper socket kits were being marked down also. Sorry no smartphone camera for pics.
That was the Champaign IL store.
BMack37
Those deals I just happened to find by walking every aisle in the store and just checking all the yellow clearance tags. Plumbing usually has some phenomenal deals, but it's usually oddball stuff that you have no use for.
For the most part, you can find Lowes deals online. I just search brands or category, such as "Hitachi" or "pliers", filter for "in store", then sort it by price. Go down the list and you'll notice some things out of place in the sorting, such as $99 $98 $12 $97 $96, there's something up with the $12.
Then keep in mind that every store is different, so if you find something discounted, change your store and check the price there
Thank you for both the advice and the deals you've been posting! :)
Here's a couple of deals. Prices will vary by store but they're as low as $3.98 for each:
Kobalt 18-in-1 Precision Screwdriver Set: http://www.lowes.com/ProductDisplay...&cm_mmc=AFF_CJ-_-4485850-_-1122587-_-10926682
Kobalt 26-Piece Ratchet Precision Screwdriver Set: http://www.lowes.com/ProductDisplay...&cm_mmc=AFF_CJ-_-4485850-_-1122587-_-10926682
onuxis
Kobalt Xtreme Access 11-Piece Pass-Through Socket Set
Item #: 379794 | Model #: 86242
60% off $3.99
40475
Kobalt Xtreme Access 10-Piece Pass-Through Socket Set
Item #: 379764 | Model #: 86241
60% Off, $5.19
40475
Looks like just about all of the "Xtreme Access" stuff is on sale or clearance. it's a neat idea, but unlikely to catch on.
onuxis
Kobalt 14-in Cast Iron Pipe Wrench
Item #: 464649 | Model #: 55770
75% Off, 3.74
40475
onuxis
I use mine all the time
To be honest, I was kind of bummed after I picked up all three sets. 1/4, 3/8, and 1/2 thinking it would fit on a normal ratchet. Now I know that's not the case and I'm headed back in the morning to pickup the adapters to make that work. Also grabbing that ratchets for the heck of it.
Just kind of irritated that they used standard ratchet naming size conventions on the packaging. The way the sockets are locked to the plastic holder, you have no real way to get a peek at the end of the socket.
Project_shadow
The set in the box comes with an adapter
I got the 3/8 1/4 case and the 1/2 case
I love using the extension with a socket because sometimes the bolts are longer than a standard deep and a wrench won't turn
Spn1025
New Hampshire
I checked online and I can't find these on sale in New York state??? :dunno:
$2.25 in Greenland NH with 2 available
$2.14 in Portland ME with 1 available
$2.25 in Salem NH with 1 available
that's all I see around me..
Not that expensive to begin with .. $8.98 full price
Paramus, NJ $2.24 with 17 in stock
Brooklyn (Kings Plaza) NY $4.49 with 143 in stock
Amsterdam NY $2.25 with 87 in stock
Ulster NY $3.59 with 32 in stock
Newburgh NY $4.49 with 15 in stock
Matamoras PA $4.49 with 46 in stock
Riverhead NY $4.49 with 11 in stock
Patchogue NY $1.10 with 15 in stock
Cazz
Denver, CO
Store Quantity Price
PATCHOGUE, NY 15 $1.10
AMSTERDAM, NY 87 $2.25
ULSTER, NY 32 $3.59
RIVERHEAD, SOUTH, NY 11 $4.49
NEWBURGH, NY 15 $4.49
BROOKLYN, KINGS PLAZA, NY 143 $4.49
(full price)
SARATOGA SPRINGS, NY 20 $8.98
ROSEDALE, NY 37 $8.98
SPRINGVILLE, NY 77 $8.98
HENRIETTA, NY 72 $8.98
ORANGEBURG, NY 47 $8.98
OGDENSBURG, NY 1 $8.98
GREENPORT, NY 19 $8.98
ITHACA, NY 70 $8.98
HICKSVILLE, NY 5 $8.98
LLOYD, NY 81 $8.98
GARDEN CITY, NY 37 $8.98
HALFMOON, NY 14 $8.98
FARMINGDALE, NY 52 $8.98
GLENMONT, NY 8 $8.98
CORTLANDVILLE, NY 70 $8.98
ALBANY-NORTHWAY MALL, NY 11 $8.98
CHESTER, NY 28 $8.98
CANANDAIGUA, NY 1 $8.98
*edit: Oops, Spn1025 updated his post with the same info.
Status
